STD Tuning Engine OM606 & 722.6 Dimensions
matfield
03-15-2015, 03:26 AM #1
Hi Lads,
This may have been done before, but I can't find it on a search. Does anyone have exact measurements from the very front most part of the 606 and the output flange of the 722.6?
Also is there a difference in length of the 722.6 that comes as standard on the E300TD and the 722.634 W 5 A 580 that came on the E270CDI?
Thanks
Mat
matfield
Hi Lads,
Thanks
Mat
zeeman
03-15-2015, 08:30 PM #2
(03-15-2015, 03:26 AM)matfield Hi Lads,
Thanks
Mat
31 inches from front of crankshaft pulley to flange were bellhousing bolts on USA 98-99 E-300 OM 606. Can't answer about the E270CDI.
This post was last modified: 03-15-2015, 08:31 PM by zeeman.
zeeman
Thanks
Mat
matfield
03-17-2015, 02:41 PM #3
Thanks for that... its looking promising. All I need to do now is find measurements for the autobox Smile
matfield
erx
w202 om606
323
03-17-2015, 05:49 PM #4
All 722.6 mercedes boxes share the same rear part of housing, only front part with bellhousing is different with different engines (I6,V6,V8). 300td and 270cdi boxes are same sizes.
This post was last modified: 03-17-2015, 05:57 PM by erx.
erx
whipplem104
03-17-2015, 07:05 PM #5
The trans is 23.5". And they are not all the same length. Because the bellhousings differ in length as well due to different crank offset to the flange.
whipplem104
