STD Tuning Engine Alda adjustment on OM606
kashi123
04-14-2015, 11:24 AM #1
Hello,
I have a G wagen with OM606 and mechanical pump with 6mm elements.
Bedore I send my pump off to dieselmeken for 7.5 mm to help on increase low torque for my g wagen I would first like to adjust my alda. This made a huge difference on my old 617a so would like to give it a go!
But I have the round style alda instead of the more common flat style one. Mine is the same as in the picture attached
Question is how do I adjust one of these, can i screw out the set screw or should I shim it up a bit, can this even be done?
Thanks for all advice
Richard
kashi123
Hello,
Richard
Rallyus
04-14-2015, 12:59 PM #2
Why on earth do you want to adjust the Alda before sending the pump to get big elements?
If it has a screw on top, just turn it...
Rallyus
04-14-2015, 01:36 PM #3
he he he , alda on those pumps dont increase any fuel. they limit fuel untill boost is present. but irespetive of that the pump will deliver almost the same amount of fuel.
if u want the alda to stop restricting , remove the screw out, all the way out is the same as remove the device.
regards
regards
kashi123
04-14-2015, 03:10 PM #4
Thank you for your replies, I didn't explain my intentions very well.
Last weekend my hydraulic pump broke off its mountings so that means I need to dissassemble the whole left side of the car to get to it and weld it back. As I am there anyway it will give me acces to the pump. And as I going on another trip in a few weeks I cant get the pump to dieselmeken in time.
Just looking for a bit more oomph from standstill for the mountains in Croatie!
As you can see quite busy under my hood Angel
kashi123
kashi123
04-14-2015, 03:12 PM #5
And another shot:
kashi123
And another shot:
Rallyus
04-14-2015, 03:26 PM #6
Adjusting the Alda will only make you smoke off boost. No real advantage...
Rallyus
kashi123
04-16-2015, 03:03 PM #7
Ok, message understood. The pump is now on its way to Sweden !
Thanks for your advice
Richard
kashi123
Richard
