STD Tuning Engine rev counter gauge
rev counter gauge
rev counter gauge
gary andrews
4x4 builder
48
04-14-2015, 04:15 PM #1
anyone know what make rev counter to use with om605 ,after a pod type cheers
discovery 2 fitted om605 m pump 7.5 elements 300 turbo at mo
c250 std at mo
off road buggy fitting om 606 turbo ? supercharger ? to follow
www.gaz-fab.co.uk www.facebook.com/gazfab
gary andrews
c250 std at mo
Mr_Robs
04-14-2015, 05:28 PM #2
You are looking for an aftermarket pod one?
If you are keeping a stock W202 gearbox you should be able to just buy an electronic tach and then buy a signal converter like this one.
http://www.summitracing.com/parts/dak-dsl-2
Mr_Robs
gary andrews
4x4 builder
48
04-15-2015, 02:22 AM #3
(04-14-2015, 05:28 PM)Mr_Robs You are looking for an aftermarket pod one?
its a land rover gearbox ,but thanks
c250 std at mo
gary andrews
c250 std at mo
04-15-2015, 04:23 AM #4
The 605 and 606 have a flywheel speed sensor on the right hand side of the block, but I double that picks up anything from your flywheel using the adapter you have. But to check you could connect an analogue multimeter to the sensor and if the needle goes bananas (the sensor outputs a sinewave signal because it is a hall effect type).
You should be able to get any after market gauge / pod thing that will pick up a hall effect sensor. Converting any other type of sensor IE a counter type requires the signal to be attenuated with a narrow band filter and is must more difficult.
