Best, Easiest Brake Upgrade W124 300TD
There are 2 version of the W124 4 piston brakes that fit inside 15" 8 hole wheels.
295x22mm rotor
294x25mm rotor
The thinner 22mm rotor found on that 91 300ce will fit without changing control arms. I put those brakes on my 87 without issue. I did remove the dust shield tho.
PDF
www.w124performance.com/docs/mb/W124/124_brakes.pdf
