STD Tuning Engine 250-300HP OM606 Turbo choice?
kmaser
Turbocharged G-Wagen
125
04-24-2015, 01:26 PM #1
I have done a lot of searching and haven't come up with a conclusion on my own so figured I would ask for advice.
I will have an OM606 with Dieselmeken 7.5mm IP in my Mercedes G with 6:17gears / 35-37" tires and I am looking for early spool much like the stock turbo but with enough extra flow to get between 250-300hp. Most of the builds on here are focused around higher HP and higher rpm. I am not too concerned with power above 4500rpm.
At the moment I have an HE221W, an HX30W and also a MHI turbo which is supposedly from an ISB Cummins which has a flap in the exhaust for variable flow through the turbine which has the following number Td04hl4sl-11kyrcn-vft. I can use any of these and I am also open to better options as I'm not sure of the flow requirements to support the HP.
Huh
kmaser
Huh
SuperG
05-24-2015, 08:42 PM #2
http://www.dieselpumpuk.com/g-wagen-conversions/
How do you think the CV joints will deal with 300hp? Huh Im pondering over this subject for my own build..
http://www.rcvperformance.com/product-de...ku=CVJ3379
Dodgy
SuperG
Dodgy
kmaser
125
05-24-2015, 09:39 PM #3
Well I have seen broken CV's on a 72hp  G240D and I have seen them live behind 300hp V8 etc. It really is about how you drive them and the CV's in 500+HP G's are no different, I don't abuse my G off road but I do want more power on the road and for pulling my trailer through the mountains.
I have considered the RCV joints before but haven't found a need yet and if they are no longer the weak link I would hate to find out it is the ring and pinion. (6:17's are harder to find on top of that).
kmaser
