STD Tuning Drivetrain W201 2.5 turbo Om602
bmartins
06-07-2015, 04:17 PM #1
Hello.
I want a single mass flywheel to my car..i already know that the 2.3 16v might fit also like the Sprinter one...but does anyone have for sure which one of these os another one is diract bolt on?
References, part numbers....all the help is apreciaed...thanks
bmartins
Hello.
06-10-2015, 03:37 PM #2
most of all flywheels and gearboxes fit the engines , and the main diff is the gearbox being for a single mass or a dual mass.
suggest the dual mass found in the w 202 250td wich u can adapt the centering bearing wich in your car is fitted in the crankshaft and the throu out bearing, wich have to be put in place for the pedal to work in the right place.
