STD Tuning Engine 3 degrees advanced timing.
TurboTim
07-01-2015, 10:55 PM #1
On my OM606 I just set the timing about 3 degrees advanced. I just want to make sure this is safe. I used 11.5 atdc instead of the 14.5. Motor is noticeably louder but I did have my motor set at 16 degrees atdc. Sounds more like my cat direct injection motor!
76 300TD custom lots of stuff
TurboTim
07-02-2015, 06:01 AM #2
if too noisy is too much advanced. Wink
TurboTim
07-02-2015, 08:53 AM #3
It's so hard to tell what too noisy is when you dont know. It's more noisy then what it was. How much are most people advancing it? I went for 16 to 11 and before it was just quiet with no clatter. Now I hear clatter but I wouldn't consider it nailing. It sounds more like my 617 engine. I wish more people actually checked there timing when they advanced it.
TurboTim
TurboTim
07-02-2015, 09:21 AM #4
I should mention my 2k all the clatter is gone.
TurboTim
07-02-2015, 10:13 AM #5
hey , turbotim who the f/&%$% cares with 12 or 13 or what ever degres u can check out with the RIV machine or the locking tool, the thing inside the pump can be assembled anywhere from 17 to 20º ..... dadda a and daaa .
if u really what to know till where u can get it trully , u got to find a stroboscopic light device!!! then u can read real advance , my car runs in the 17.5 to 18 BTDC. MB say u should use it at 16º .
u said it was louder , it shouldn´t be lauder just cause u advanced it 2ºC that is nothing......
TKMad
07-02-2015, 11:38 AM #6
How does it drive? When I was programming ignition curves for one of my Megasquirt projects I would time (datalog) a WOT 2nd gear run from 15 mph to 60 mph to see if there was an improvement.
The butt dyno is notoriously inaccurate!
TKMad
07-02-2015, 11:57 AM #7
Dieselmeken says to time his pumps at 10-12*.
https://www.youtube.com/watch?v=2DHD6UoALto @ 11:51
kashi123
07-02-2015, 02:14 PM #8
Mine is timed at 11 atdc with a 7.5mm dieselmeken pump.
It is certainly louder, more of a rasp I would say. Indeed a higher revs smooth as silk.
Still louder than 6mm elements at 14 atdc but so much more power
I will if you like upload some cold and hot idling videos?
kashi123
