STD Tuning Engine 190 TD low boost?
190 TD low boost?
190 TD low boost?
CMP
08-09-2015, 04:45 AM #1
Hello.
I have an `89  190 2.5 Td.
I recently noticed a decrease in performance.
Everything seems to be in order.
I installed a manometer and produces only 0.5 bar boost.
With wastegate off only produces 0.65 bar.
The gauge is connected to the output of manifold to Alda, is that correct?
Wanted to know what you think of these values.
Thank you very much in advance.
Regards.
CMP
Hello.
Regards.
08-09-2015, 07:24 AM #2
something is wrong, for sure...
u should conect the boost indicator in the engine plennum. and be sure there´s no leak in the system or clogging.
it can be due many things, 89 car sold in europe should have EGR system? correct?
if i were u i would start by , leaks, after be sure EGR system operates, then we´ll what else.
sometimes a small thing like a leaking vac line lead to that.
Regards...
Regards...
CMP
08-09-2015, 05:04 PM #3
Thank you very much, Barrote.
My car does not have EGR.
I will repeat the test with another gauge to see if it has same results.
It should reach about 0.85 Bar, right?
Greetings!
CMP
Greetings!
anjay
1998 E300 Turbodiesel
57
08-09-2015, 05:18 PM #4
When did you changed fuel filter? I would check to make sure is not clogged.
1987 300TD - tinker toy
1989 300TE - parts
1991 300TE - backyards decor
1991 300TD - Barrote’s 7.5
1998 ML320 - snow ride
anjay
1989 300TE - parts
CMP
08-09-2015, 05:27 PM #5
Hello Anjay.
Air and fuel filters only have 8000 km.
I will change the fuel filter again to secure. (I have pending to check the filter at the tank)
Thanks and greetings!
CMP
Hello Anjay.
CMP
08-12-2015, 04:27 AM #6
Hello, good day.
It seems that already goes well.
I deleted solenoid between manifold and alda, now boost is 0.8 bar.
It seems that the problem was in that piece.
Regards.
CMP
Hello, good day.
Regards.
