STD Tuning Engine Dawes device
Dawes device
Dawes device
Keino
09-12-2015, 11:33 AM #1
Hi!
Anyone of you familiar with a solution called "Dawes device"?
Thing is I want to turn up my boost.
Im using 617.952 with 7.5mm Dieselmeken pump and a Borgwarner S200G @ 1.9bar boost (27.5psi)
Wanna go a bit higher. Maybe 2.3Bar or so.
The wastegate I have looks something like this:
http://i926.photobucket.com/albums/ad109...040236.jpg (Not my turbo)
The device, as I understand is to be mounted between the compressorhousing and the wastegate on the vacuum line.
There is a screw on the device to adjust how much air passes on to the wastegate in order to adjust the boost pressure, without touching the wastegate.
http://www.fordclubsweden.se/forum/attac...1267212305
That's how I think it works anyway.
Anyone have input? Tried it?  Good/bad?
If this solution is no good, then I might be looking for a stronger spring for the wastegate. Hard to find though it seems.
Mostly I get from google search is gas tuning parts  (Less than a bar boost Big Grin  )
Keino
Hi!
led-panzer
09-12-2015, 02:24 PM #2
I actually just bought one, have to see how it does
1985 300D 280,000 miles RIP
led-panzer
hooblah
09-12-2015, 02:27 PM #3
It would work if you have electronic fuel injection. It will still work to open the wastegate later on a mechanical injection system, but there will be no increase in fuel. Kinda pointless really. But give it a go and see what happens.
hooblah
Keino
09-12-2015, 02:33 PM #4
(09-12-2015, 02:24 PM)led-panzer I actually just bought one, have to see how it does
Same here. Bet you will mount it before I do ^^
Be sure to post results Big Grin
Is she still running great? =)
Keino
led-panzer
09-12-2015, 02:52 PM #5
Still going strong Smile
Need to finish the exhaust out the back
led-panzer
Petar
7.5mm M pump
459
09-12-2015, 04:44 PM #6
Also known as the ball and spring manual boost controller. Never tried it myself but people say it works pretty well.
It has a ball pressed on a set by a spring and on the other side of ball there is input pressure. The ball blocks the flow of air until the air pressure over comes the spring.
A side benefit is that it can keep the Wastegate fully closed longer during spool up, which allows the turbo to spool faster and be more responsive.
[Image: boost_controller.sized.jpg]
This post was last modified: 09-12-2015, 04:45 PM by Petar.
Petar
led-panzer
09-12-2015, 06:15 PM #7
The Dawes boost controller bleeds boost off via a third office to let you run higher boost levels
led-panzer
m1tch
09-13-2015, 10:56 AM #8
Its just a basic bleed manual boost controller?
m1tch
09-13-2015, 09:15 PM #9
LOL. I had to google what a dawes device was. I was sure it was going to be awesome.
ho55
09-17-2015, 05:48 AM #10
The Volvo D24T had one on it when i bought the vehicle, it seemed to control the boost quite nicely.
ho55
F.R.A.S
09-19-2015, 10:07 AM #11
Dawes Device is an awesome boost controller that gives you rock steady boost. I personaly use it in every manual build where a MAC-valve can't be used.
F.R.A.S
09-21-2015, 06:39 AM #12
(09-19-2015, 10:07 AM)F.R.A.S Dawes Device is an awesome boost controller that gives you rock steady boost. I personaly use it in every manual build where a MAC-valve can't be used.
it looks like it is to help stop wastegate creep?
awsrock
300SDL / HX30 / 90cc
179
09-25-2015, 12:20 PM #13
I just got one of these. I had a cheap ebay one on my old 300D. For a stock car that is automatic, the biggest change is that when the car shifts gears around 2000-2200 rpm, it keeps that strong boost in the next gear. I think it makes driving in traffic much smoother. And yes, if you have wastegate creep, this will eliminate it. I am happy again so far. My only complaint about the Dawes MKII is that one of the nipples is smaller than the other, so I had to fiddle with some attachments to make it fit the wastegate hose.
awsrock
