STD Tuning Engine Superpump fuel stop
Superpump fuel stop
Superpump fuel stop
monstercrawlers
10-16-2015, 04:28 PM #1
Has any one got and part numbers for a reliable vacuum solenoid that can be used as a fuel stop valve.
monstercrawlers
deviance
HE351VE
88
10-18-2015, 09:44 AM #2
Mercedes? in VW is called N75 that's works too.
deviance
EvoPeter
10-19-2015, 05:53 AM #3
I use Mercedes EGR solenoid valve as everyone else in Sweden do.
The N75 is expensive. But its good for me cuz i sell them secondhand from scraped Audis my girlfriend buy.
EvoPeter
gary andrews
4x4 builder
48
10-19-2015, 02:31 PM #4
ive had problems with these shutting the valve off when driving and not starting some times till i pull one of the lines ???
This post was last modified: 10-19-2015, 02:32 PM by gary andrews.
discovery 2 fitted om605 m pump 7.5 elements 300 turbo at mo
c250 std at mo
off road buggy fitting om 606 turbo ? supercharger ? to follow
www.gaz-fab.co.uk www.facebook.com/gazfab
gary andrews
c250 std at mo
Tito
10-19-2015, 03:25 PM #5
the Vw N75 or the mercedes? The N75 is notorious for braking down. I have a stack in stock at my job. However I think it will do the job just fine. If they're mounted on the chassis its away from the turbo heat and vibrations.
Tito
EvoPeter
10-20-2015, 01:03 AM #6
(10-19-2015, 02:31 PM)gary andrews ive had problems with these shutting the valve off when driving and not starting some times till i pull one of the lines ???
If you connect it correctly it wont be a problem. I have installed these mercedes egr solenoid valves in 2 mercedes and never had a problem.
EvoPeter
deviance
HE351VE
88
10-20-2015, 01:58 PM #7
(10-19-2015, 05:53 AM)EvoPeter I use Mercedes EGR solenoid valve as everyone else in Sweden do.
N75 expensive?
20 euro.
This post was last modified: 10-20-2015, 01:59 PM by deviance.
deviance
N75 expensive?
20 euro.
