M-Pump priming
M-Pump priming
Hi, all.
Yesterday was the first trip out with the M pump and found egt's to be on higher side settling in around 825-75° so I turned down fuel n boost in an attempt to get them lower.
This morning went out to drive it again and keeping adjusting till a better egt can be maintained BUT....it won't start!!!
Changed filters after a lines had been cracked and no fuel, hooked up electric pump and still no fuel through lines, even turned fuel adjustment back up just in case and still no fuel through lines,
What next?.....it's a DD during cold weather n running out of warm days.
Thanks
He has deiselmeken m pump with external adjustments...
Celsius
