STD Tuning Engine increase injection pressure om605
Repetitio
10-26-2015, 12:46 AM #1
Hi,
since i want to keep my stock elements (6mm) and max out the pump to it´s maximum i thought about increasing the injection pressure for shorter injection times to lower my egt´s. Is that possible at a w202 250 td? And how can it be done? Via Remap or manual?
This post was last modified: 10-26-2015, 12:46 AM by Repetitio.
Repetitio
Hi,
10-26-2015, 02:08 AM #2
only thing u can do in that istallation , is incresse injector pop pressure, from 135BAR to what else u consider to be a good thing for u...
usually people use 150BAR. but i´m not so sure of benefits.... despite i have mine in that range too.
if u have EGT problems with a 6mm pump, something is very wrong, that can only mean 2 things engine is running outside timing or u have massive EGP ... if i were u i would start that road...
u still using the EDC pump?
Repetitio
10-26-2015, 02:32 AM #3
yes still edc pump with resistor and bigger turbo. I will wait for the remap, that might also help in egt´s. I also still have the stock exhaust, i´ll remove it completely and check egt´s again Smile Thanks barrote!
Repetitio
10-26-2015, 02:36 AM #4
what kind of EGT´s are u talking about? i found stange cause usually is coolant temp that people complain .....
Repetitio
10-26-2015, 03:58 AM #5
i reach like 700°C fast. After full accelerating 2nd 3rd and 4th gear. Isn´t that high? Big Grin
Repetitio
10-26-2015, 04:06 AM #6
no ... high is when u reach 1000º Hill climbing ....
yes is a kind of high for what a 6mm pump can do , something is wrong there...
check your camshaft timing , and pump timing(theres no reason to use the pump too much advancedaround 13º/14º is ok)... if all is ok then u have massive back pressure , u should find another turbo hehhe or exaust hhehe
this is my opinion and only my opinion... take as it is
regards
Ps: i´m assuming u have a decent charge cooler !!! clean intake dada those things
This post was last modified: 10-26-2015, 04:08 AM by barrote.
regards
Volker407
naturally aspirated
157
10-27-2015, 04:31 PM #7
(10-26-2015, 04:06 AM)barrote ...u have massive back pressure , u should find another ... exaust.....
+1 for much too high backpressure
My W202 250TD sometimes even had backpressure  caused overheating with still stock engine and stock exhaust.
Plan for a 76mm exhaust with free flow mufflers , that did help....
Gruß
Volker
Volker407
Gruß
Volker
m1tch
10-28-2015, 03:02 AM #8
Increasing the pop pressure on the injectors will alter the timing, standard turbo injectors are 135 bar, I believe for certain pumps setting them to 140 bar works (but I am guessing the pump timing isn't stock).
m1tch
