STD Tuning Engine Thoughts about om605 with om602 2,9 crank
EvoPeter
11-12-2015, 04:10 AM #1
Whats your thoughts about stroking a om605 with a crank from a om602 2,9?
I read somewhere that it would make it a 2,7L.
Good or Bad?
EvoPeter
Good or Bad?
11-12-2015, 04:59 AM #2
Hy ,
i´m doing a similar thing,
it does work , however u need diff tipe rod, the piston stick out 2.5 mm , is too much and then u have to balange the set ...
but it does not give u 2.7lts, the 2.9 crank is 91.3mm stroke .
Hy ,
