STD Tuning Engine Schwitzer S200 om603
Xzitenz
12-18-2015, 06:46 AM #1
Was wondering how this would work. I actually allready have the turbo installed, but still stock pump. Planning on a 7.5.
Compressor in: 53mm
Turbine ex: 65mm
T3 twin inlet
Came off a 7.4 deutz straight 6.
Would this work or is it shit?
Xzitenz
Compressor in: 53mm
Turbine ex: 65mm
T3 twin inlet
12-18-2015, 12:25 PM #2
That would be very similar to a holset hx35, only a little smaller. How big is the exhaust housing? Most engines that size have exhaust housings much too large for our application.
Xzitenz
12-18-2015, 01:04 PM #3
I have no idea about the size, there isnt any stamps or anything. But it looks pretty big. The deutz it was ment for was a 200kva generator set. Might as well just get a hx35 or something then.
Xzitenz
12-18-2015, 03:04 PM #4
I wouldn't get rid of it yet. A smaller housing, say a .91, .88, or .83 should make that turbo a good match for a 603. Just make sure your turbine clears the housing! Several people around me have machined out the inside of the housing to fit a smaller housing to a larger turbine.
Xzitenz
12-18-2015, 03:58 PM #5
Okay thanks, maybe I should give it a go!
Xzitenz
