STD Tuning Engine Fpr
Fpr
Fpr
Frank606
01-10-2016, 11:28 AM #1
After looking a lot on this issue Looking to install a 044 Bosch pump for my project
Can any one advise what type of FPR I can use for this operation
Frank606
TurboTim
01-10-2016, 11:53 AM #2
I ran with the stock spring fuel pressure regulator in the banjo bolt then switched to an aftermarket style fpr at 30# and noticed no difference in performance. If you do switch to external fpr you have to figure out a way to return the fuel from the injectors
76 300TD custom lots of stuff
TurboTim
