STD Tuning Engine om617 95C* Oil thermostat
Evenglass
01-10-2016, 04:44 PM #1
I'm looking for a 95C* oil thermostat for the filter housing, new, used don't really care as long as it works. I've searched hi and low and cannot find one. If I can't find one here (on this must excellent forum) what did they come in so that I can scrounge the yards?
This post was last modified: 01-10-2016, 04:52 PM by Evenglass.
Evenglass
Petar
7.5mm M pump
459
01-11-2016, 04:47 PM #2
I dont think it's a good idea, the oil temp must reguraly exceed 100*C so that moisture can boil out.
Petar
Tito
01-11-2016, 04:58 PM #3
Water will evaporate at 95*C. It just takes a little bit longer but there shouldn't be much water in the oil.
Also oil will pass the turbo and head where temperatures exceed 100*C
This post was last modified: 01-11-2016, 04:59 PM by Tito.
Tito
Evenglass
01-11-2016, 06:36 PM #4
(01-11-2016, 04:58 PM)Tito Water will evaporate at 95*C. It just takes a little bit longer but there shouldn't be much water in the oil.
Thats is correct. Regardless of sump tempreture the oil exiting the crank is in the 230-250* range. Mercedes increased the oil temp to decrease warm up time and reduce pumping loses due to oil viscosity. Modern synthetic oils do a great job of reaching proper viscosity quickly and without such high heat. Anybody have one of these lying around?
Evenglass
