STD Tuning Engine DSL1 controller
DSL1 controller
DSL1 controller
  • 1 Vote(s) - 5 Average
baldur
Fast
506
02-01-2016, 06:02 AM #51
(02-01-2016, 05:15 AM)Hario
(01-31-2016, 06:24 PM)maxypriest Can you run the edc pump without the stop valve on the side with this unit?
The stop solenoid just needs 12v switched live to open.
Yes, but you can also remove the stop solenoid. That's what I did on my car because I did not have the right filter housing to connect the two extra lines, nor did I have the electrical connector to connect it.
I just turned an adapter on the lathe to replace it. There's no harm in keeping the solenoid if it's already plumbed in.
[Image: ntX4QRI.jpg]
[Image: jJUWmT1.jpg]
This post was last modified: 02-01-2016, 06:05 AM by baldur.
Baldur Gislason
baldur
Baldur Gislason
maxypriest
02-01-2016, 11:25 AM #52
Perfect. Thanks.
maxypriest
Perfect. Thanks.
50harleyrider
GTA2359VK
397
02-04-2016, 01:00 PM #53
(02-01-2016, 11:25 AM)maxypriest Perfect. Thanks.
Got some photos?
50harleyrider
Got some photos?
97e300
(its a 98 now)
109
02-24-2016, 03:49 PM #54
Anyone install a dsl1 yet? Impressions, vids?
97e300
baldur
Fast
506
03-15-2016, 05:35 PM #55
I believe none of the units I have exported have been fitted to engines yet, as I have not received any feedback from those customers. I have some customers running the controllers locally and as far as I know they are not experiencing anything other than good performance and trouble free operation.
I have been using the ECU on my daily driver for 3 months (in the software business they call this eating your own dog food), and I've been pleased with the result myself. The only observation I made was that the control loops for idle and rack position favoured different parameters on a cold engine versus a warmed up engine.
As a result, the latest firmware has those parameters configurable based on coolant temperature.
Baldur Gislason
baldur
Baldur Gislason
baldur
Fast
506
08-08-2016, 08:06 PM #56
Time for an update. I've heard from a number of customers who have gotten their cars driving and none have reported any issues.
I also got my own car fixed with a new engine and wired some units to other local cars so I was able to resume development of the firmware.
I've released firmware version 1.7, and what this version brings new is working and thoroughly tested cruise control, general purpose PWM outputs (I used this to mimick the vacuum control valve to operate a 722.3 transmission), configurable analog input filtering and some minor changes to the CAN bus custom broadcast packet constructor.
Here's a harness I made for running an OM662 engine, not including the pump wiring which is separate. This one has wiring for MAP sensor, accelerator pedal sensor, engine speed sensor, coolant temperature sensor and boost control solenoid, and includes a relay to power the unit directly from the battery.
[Image: 2016_08_06_17_30_57.sized.jpg]
[Image: 2016_08_07_23_31_49.sized.jpg]
Baldur Gislason
baldur
Baldur Gislason
50harleyrider
GTA2359VK
397
08-12-2016, 05:18 AM #57
Hi Baldur,
I just finished bolting my engine onto the E4OD and it's in the truck waiting for me to fab motor mounts and check final clearances. Then onto the ecu wiring. Don't give up on me. Do you have a good source for wiring shrink wrap you show in your photo? I'd like to use it inside the split hard plastic looms I'm using. One can't protect wiring enough inside a hot engine compartment.
50harleyrider
Hi Baldur,
baldur
Fast
506
08-12-2016, 05:58 AM #58
The shrink wrap I purchased locally, but I know of two companies on your side of the pond that have a good selection of quality wiring supplies.
Pro Wire USA specialises in wiring supplies, professional grade stuff but some of it can be a bit pricey.
Aircraft Spruce also has a selection of wiring supplies, most of them at a fair price.
You can probably get suitable stuff from any electrical/electronics supplier.
Heat shrink tubing is excellent for abrasion and vibration resistance. Use soft flexible stuff (non adhesive lined) to cover the length of the wiring. Adhesive lined tubing is good for covering branch points and ends near connectors. If you need to splice wires inside the harness, the best method is to use duraseal/permaseal type crimp splices which come with adhesive lined heat shrink tubing for a sealed and strain relieved splice. Avoid soldering inside the wiring harness as it makes the wires brittle and prone to break in an environment where there's vibration present.
Baldur Gislason
baldur
Baldur Gislason
08-12-2016, 12:27 PM #59
I get mine from Zoro. I like the large diameter non-adhesive stuff to cover the entire loom. Looks tidy. The adhesive stuff is good for under hood use since it seals splices from fluids and the elements.
erx
w202 om606
323
09-03-2016, 04:45 PM #60
I don't have om606 6 lug/notch flywheel, so I have to use hall effect sensor from damper TDC stud and just have to choose this option in sensor input menu? If I have Ole's 722.6 controller also, then can I use one TPS sensor for both units? I read that they can be connected to each other with canbus, is there more information about this? About reducing engine power during shifts and sharing sensors.
This post was last modified: 09-03-2016, 04:49 PM by erx.
erx
jhw.
09-03-2016, 05:09 PM #61
Do you sell the looms too?
jhw.
baldur
Fast
506
09-03-2016, 08:26 PM #62
Regarding the TDC stud, I've had even better results using the starter ring gear for engine speed sensing (and some of these engines have provisions for a sensor there from the factory). Only getting speed information once per engine revolution is not optimal for low speed drivability with a manual transmission. For an automatic it doesn't matter at all.
If you have Ole's controller you can use one TPS for both units but for signal integrity I would recommend sharing sensors over the CAN bus rather than split wiring. I need to add a section covering this to the documentation.
For the looms, I do not currently have a good source of connectors for the pedal position sensors, but I could supply a loom with flying leads if you gave me approximate lengths for your application. For such special order items you'd be best off getting in touch by e-mail to discuss your needs and we'll figure out how I can fulfill them and at what cost.
This post was last modified: 09-03-2016, 08:27 PM by baldur.
Baldur Gislason
baldur
Baldur Gislason
erx
w202 om606
323
09-04-2016, 04:12 AM #63
At the moment I have 722.6 Ole controller and Dieselmeken M pump, flywheel/flexplate is self made so no 6 studs but stock starter ring gear sensor is used for tacho, so can I split sensor wiring between tacho and DSL1? Sensor is with angled tip and locates in oil sump where it's from factory.
I have to contact Ole about CAN bus connecting because my controller is bought year ago. I belive I need to upgrade software and I hope that older modules support this option.
With Ole controller I have MAP sensor for 3bar boost, do they share this also with CAN bus? And what happens when I have over 3 bar boost?
This post was last modified: 09-04-2016, 04:42 AM by erx.
erx
baldur
Fast
506
09-04-2016, 05:55 AM #64
You should be able to share them, but it may be necessary to desolder a pull-up resistor from the DSL1 board for the sensor to output a signal strong enough during cranking. You will also need to know the number of teeth on your ring gear to configure it.
The DSL1 controller needs a MAP sensor wired directly but it is able to transmit that data over the CAN bus. If you exceed the range of the MAP sensor you just won't be able to use the boost control functionality or log how much boost you were actually getting. It's better to get a 5 bar or 7 bar MAP sensor in that case.
Baldur Gislason
baldur
Baldur Gislason
erx
w202 om606
323
09-04-2016, 10:58 AM #65
(09-04-2016, 05:55 AM)baldur You should be able to share them, but it may be necessary to desolder a pull-up resistor from the DSL1 board for the sensor to output a signal strong enough during cranking. You will also need to know the number of teeth on your ring gear to configure it.
I asked Ole and he said that CAN bus is working only with new OLED graphics display, so I have to order it from him. He also said that data is transmitted only one way from DSL1 to Ole's 722.6 controller, so I need to connect all sensors to DSL1 and then CAN bus is sending data to Ole's controller.
erx
erx
w202 om606
323
09-08-2016, 04:16 AM #66
Do you have video of this? How it revs and goes back to idle, just from under the bonnet.
This post was last modified: 09-08-2016, 05:00 AM by erx.
erx
baldur
Fast
506
09-09-2016, 11:52 AM #67
I have this video:
https://www.youtube.com/watch?v=06nLARTUltc
Baldur Gislason
baldur
I have this video:
Baldur Gislason
wanger
09-11-2016, 04:13 PM #68
Hi, how much of the original loom from the e300 is required? i'm taking the engine and box out currently. gonna try and strip the whole loom cause i want the EDC pump but if the DSL1 is a option id like to now whats really required.
-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-
om606 into Defender 110  Cool
wanger
baldur
Fast
506
09-11-2016, 07:00 PM #69
You need the throttle pedal position sensor and the MAP sensor, the rest of the wiring you need is all in the loom that comes off the engine and terminates in a green connector on the cars I've seen.
Baldur Gislason
baldur
Baldur Gislason
wanger
09-12-2016, 03:07 PM #70
ok so TPS and Map switch. Is the map switch already on the engine?
i'll run mine standard for a while so will the DSL1 be able to control the turbo actuator or will i have to change it to a transit style one?
wanger
baldur
Fast
506
09-12-2016, 04:36 PM #71
The MAP sensor is on the firewall somewhere, connected to the fitting that bolts to the inlet manifold by a piece of hose.
You can use the standard turbocharger actuator, you will need the vacuum solenoid for that.
Baldur Gislason
baldur
Baldur Gislason
baldur
Fast
506
12-28-2016, 04:34 PM #72
I have kept busy improving the software. Most notably, now the Calibrator software has a graphical data log viewer built in.
[Image: logview.png]
[Image: scatter.png]
[Image: histogram.png]
Baldur Gislason
baldur
Baldur Gislason
wanger
12-28-2016, 05:17 PM #73
great to see the developement.
wanger
hents99
12-28-2016, 06:27 PM #74
Yesterday another W463 started to run with OM606 and with DSL1 ecu. Nice and easy.
hents99
matfield
12-30-2016, 05:18 AM #75
Just to add my 2c, I have Baldur's DSL1 up and running in my Defender 110, and it is an amazing piece of kit. The software that Baldur provides is very intuitive, and once I had the loom made up, I was able to test and calibrate everything and start in about an hour of first turning the ignition on.
Combine that with Baldur's backup via email, I can't recommend it enough! I'm yet to get serious mileage under my belt, but I've done a few full power runs and it is factory quality smooth, using the base tune that Baldur provides, and a completely stock engine, so the potential is very exciting.
Mat
matfield
Mat
INC
12-30-2016, 03:16 PM #76
I see in ofgear page, that ole`s TCU controler can talk with DSL1 controler. Is it possible that they can work together and DSL1 can limit torque while TCU make shifts?
INC
baldur
Fast
506
12-30-2016, 04:48 PM #77
Not in the current firmware version, but that feature is planned for a soon to be released version of my firmware.
Baldur Gislason
baldur
Baldur Gislason
baldur
Fast
506
03-14-2017, 08:16 PM #78
I have made a new firmware release, with lots of new features and improvements.
From the release notes:
- Reformed idle control strategy for a smoother and more reliable return to idle.
- Added option of idle-up inputs.
- Cruise control engagement made smoother.
- CAN receive inputs now have configurable default values and timeouts.
- There are now 8 general purpose logic conditions in place of 4.
- After start glow timing no longer limited to 25.5 seconds.
- Vehicle speed can now be taken from CAN bus.
- Internal data logging now triggerable by a logic condition or manually instead of only engine speed.
- Internal data logging now has options to limit log file size for more convenient handling of long logs.
- Internal data logging now has burstable log rate to capture extra detail when deemed interesting.
- General purpose fuel limiters added, enabling engine torque reduction on demand or when sensor values deem necessary.
- Password protection of controllers now possible to prevent unauthorized changes. Can optionally allow access to data logging and diagnostics functions without password.
Baldur Gislason
baldur
Baldur Gislason
50harleyrider
GTA2359VK
397
03-15-2017, 08:29 AM #79
Should I go ahead and download and install this 1.12 firmware? Anything we should be aware of doing the install? Send me an email if you prefer.
This post was last modified: 03-15-2017, 08:32 AM by 50harleyrider.
50harleyrider
baldur
Fast
506
03-15-2017, 09:59 AM #80
For most users the only significant change is the idle strategy which now has programmable control over return to idle behaveour. You should probably download this and install it eventually but until you have the car ready to drive there's really no need to apply the upgrade.
Baldur
Baldur Gislason
baldur
Baldur
Baldur Gislason
03-16-2017, 11:15 AM #81
To anyone hesitating:
I've visited Baldur's shop in person, he's got some wild stuff brewing. Definitely knows what he's doing.
(01-14-2016, 09:19 AM)CRD4x4 Baldur, I have a friend (and fellow STD member) that'll be near you the 2nd week of February. You think I could have him pick up a 606a controller in person? Hopefully you'll also help me talk him out of driving the ring road in February in a rental Jeep with his wife. That's gonna be brutal!
PM me price please.
Hey! The Eastfjords were a bit hairy (1" ice, 60mph crosswind, and ranbow unicorn brand tyres) but we made it Big Grin
This post was last modified: 03-16-2017, 11:17 AM by Simpler=Better.
PM me price please.
hummermaniac88
04-02-2017, 10:27 PM #82
Anyone have this paired up with a HX40W? I can't seem to see if someone covered if this works with a VGT/VNT holset?
hummermaniac88
baldur
Fast
506
04-03-2017, 08:11 AM #83
(04-02-2017, 10:27 PM)hummermaniac88 Anyone have this paired up with a HX40W? I can't seem to see if someone covered if this works with a VGT/VNT holset?
I am not aware of anyone using that combination at the moment, however according to what information I have seen about this turbo it can be supported by the current firmware as the CAN bus implementation is extremely versatile, you can configure a CAN output that sends boost control commands to a specified CAN address in a specified format.
Baldur Gislason
baldur
Baldur Gislason
hummermaniac88
04-03-2017, 09:08 PM #84
Thanks for always helping with my beginner questions!
I have another one for you. Do i need the stock ECU with the dsl1 controller like a piggy back?
hummermaniac88
baldur
Fast
506
04-04-2017, 07:36 AM #85
(04-03-2017, 09:08 PM)hummermaniac88 Thanks for always helping with my beginner questions!
No, the stock ECU is not used with the DSL1 controller.
Baldur Gislason
baldur
Baldur Gislason
hummermaniac88
04-10-2017, 06:21 AM #86
Does this come with a prefabricated harness? Is it possible to have it pre-tuned for a certain CC and boost, so all it'll need is fine tuning?
hummermaniac88
baldur
Fast
506
04-10-2017, 02:36 PM #87
It currently does not, but there is not a great number of wires needed to make it work.
Baldur Gislason
baldur
Baldur Gislason
Evgeniy1987
04-13-2017, 07:47 AM #88
Yesterday, a friend sent me his configuration file for 8mm pump .. and a log.
To view them, I had to download the BG Configurator software. But I will need it in the near future anyway, so that is okay.. And..
I am impressed!!! It looks fascinating. Extremely detailed.. looks user friendly, has very many options.. My compliments!
I will be buying a DSL1 soon, so the software is a good start to have a look through it..
Evgeniy1987
50harleyrider
GTA2359VK
397
04-13-2017, 03:21 PM #89
Bump the DSL1. Get one! My f150 606 swap is up and running. Couldn't be happier! It's awesome how much more low end grunt it has over the crap 5.4 and I haven't even begun to play with tuning. The initial tune Baldur put in it is impressive with no engine mods other than EGR delete and a substantial intercooler. The oe kkk turbo zooms up to 1.5 bar quickly and lag free. I also have to bump the Baumann USSHIFT tcu. It works seamlessly with the 606 and the E4OD. Big Grin
This post was last modified: 04-13-2017, 03:33 PM by 50harleyrider.
50harleyrider
Mr.Emo
Nissan Patrol -> 606 conversion.
69
08-17-2017, 03:20 AM #90
Do you have a map that is more or less stock with little smoke? I'm going to get this approved in a patrol in Norway and they are very strict.
Mr.Emo
baldur
Fast
506
08-17-2017, 07:03 PM #91
(08-17-2017, 03:20 AM)Mr.Emo Do you have a map that is more or less stock with little smoke? I'm going to get this approved in a patrol in Norway and they are very strict.
Yes I can send you a map like that.
Baldur Gislason
baldur
Baldur Gislason
Mr.Emo
69
08-19-2017, 02:03 AM #92
Awesome. I will be placing an order as soon as I have the chance. Is it easy to adjust maps etc? I've never done that before. Smile
Mr.Emo
baldur
Fast
506
08-19-2017, 06:22 AM #93
(08-19-2017, 02:03 AM)Mr.Emo Awesome. I will be placing an order as soon as I have the chance. Is it easy to adjust maps etc? I've never done that before. Smile
Yes it's reasonably easy, and can be done with the engine running so you can see what difference the changes make immediately.
Baldur Gislason
baldur
Baldur Gislason
baldur
Fast
506
09-25-2017, 11:30 AM #94
I have released new firmware, as I revisited the water/methanol system I used to run on my old car and fitted that to my new car. The new firmware now includes the ability to control water/methanol injection without the need for a separate control box.
Baldur Gislason
baldur
Baldur Gislason
Mr.Emo
69
09-26-2017, 12:55 AM #95
Say whaat. How? Smile I have a water/meth kit from devils with a 30psi progressive kit.
Mr.Emo
baldur
Fast
506
09-26-2017, 08:00 AM #96
(09-26-2017, 12:55 AM)Mr.Emo Say whaat. How? Smile I have a water/meth kit from devils with a 30psi progressive kit.
The controller can switch the pump on using a relay and it can also use a solid state relay to vary the pump speed based on engine speed and throttle position or MAP. So it basically does what a progressive controller shipped with these kits does but with more options.
Baldur Gislason
baldur
Baldur Gislason
jav1
09-26-2017, 08:20 AM #97
Baldur-
question- do you have any way to connect the controller to a standard OBD port connector? It would be nice to have the ability to trigger a check engine light and perhaps generate readiness for inspections.
jav1
Baldur-
baldur
Fast
506
09-26-2017, 08:23 AM #98
Oh, and I should add, the latest configuration now also includes a CAN preset that makes a W210 instrument cluster work (speedometer, tachometer, temperature gauge). May be an attractive option for a retrofit in those old cars that have cable operated speedometers but no place to connect the cable.
Baldur Gislason
baldur
Baldur Gislason
CutWeldDrive
09-26-2017, 09:49 AM #99
hi Baldur,
is there an IP rating for the controller.
is it safe to place in engine bay or is it best to place inside vehicle
thanks
CutWeldDrive
hi Baldur,
thanks
jav1
09-26-2017, 01:31 PM #100
Baldur-
I'm reading that the om606 needs tabs on the flywheel for crank position... is this correct even with the DSL1? I'm trying to go manual transmission and want to know if I need to address that on the flywheel.
jav1
Baldur-
