STD Tuning Engine Electronic supercharger no longer a joke?
09-22-2009, 11:01 AM #1
http://jalopnik.com/5365041/electric-sup...ther-ideas
Discuss.
Discuss.
09-22-2009, 02:31 PM #2
They exist and are well known to true turbo builders like Holset and Garrett. For it to actually work though, it takes several kilowatts of electrical power.
They don't mention watts or amps anywhere in that article (for good reason). In a 12V system that would take 100-400amps of power to actually work. Thats why others have tried it using 24v, 48v and 72v systems. At best, it would be intermittently usable for ~10 seconds at a time but the actual use time would be based around the battery capacity. Alternator output wouldn't matter at all since having it supply the amperage would be counterproductive and inefficient.
99.99999% of "electric superchargers" are nothing more than bilge blowers and HVAC fans that do absolutely nothing but make scammers rich.
This post was last modified: 09-22-2009, 02:32 PM by ForcedInduction.
kamel
Naturally-aspirated SUCKS
176
09-22-2009, 02:52 PM #3
Why when a turbo does the same job more efficiently?
kamel
09-22-2009, 02:55 PM #4
Packaging, location and operation independent of the engine are about it.
Kiwibacon
09-22-2009, 03:32 PM #5
(09-22-2009, 02:52 PM)kamel Why when a turbo does the same job more efficiently?
The only job for an electric supercharger like this is to get the turbo out of bed early.
They work for a few seconds, then suck your alternator to death for the next minute or so.
Kiwibacon
09-22-2009, 03:58 PM #6
You would be better off with a gas powered leaf blower!!!! I knew a kit who put one on a Honda and made 30psi and set the internals of his engine on FIRE he took off the oil cap and flames shot out!!! LOL
09-22-2009, 10:14 PM #7
I've thought about that. Get a small ~150cc engine to power a blower in the trunk and have a wastegate actuator on the throttle to automatically maintain constant boost.
This post was last modified: 09-22-2009, 10:15 PM by ForcedInduction.
Kozuka
I'm_Badass
334
09-23-2009, 05:11 AM #8
I'm sorry but the only way is to have a gas turbine engine with a shaft comming off the turbine spinning the compressor side of a turbo feeding the engine constant 80psi and fuel consumption is measured in GPM. But man no lag and full power..
Big Grin
Kozuka
Big Grin
Kiwibacon
09-23-2009, 03:00 PM #9
(09-23-2009, 05:11 AM)Kozuka I'm sorry but the only way is to have a gas turbine engine with a shaft comming off the turbine spinning the compressor side of a turbo feeding the engine constant 80psi and fuel consumption is measured in GPM. But man no lag and full power..
Big Grin
AKA Hyperbar.Angel
Kiwibacon
Big Grin
AKA Hyperbar.Angel
tantank79
T3-45
109
09-28-2009, 05:49 AM #10
Hyperbar?
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
Hyperbar?
-Brian
1983 300TD
1982 240D
1981 280TE
Kiwibacon
09-28-2009, 03:37 PM #11
(09-28-2009, 05:49 AM)tantank79 Hyperbar?
With a username like Tantank, you should know.Big Grin
Quote:The "hyperbar" system integrates a Turbomeca TM 307B gas turbine in the engine, acting both as a turbocharger and an APU giving auxiliary power to all systems when the main engine is shut down.
http://en.wikipedia.org/wiki/Leclerc
Google "SACM Hyperbar"
Kiwibacon
 3 Guest(s)
 3 Guest(s)
