STD Tuning Engine Diy egr block off advice
Dark Hawk
02-28-2016, 05:37 PM #1
I am planning on blocking off the egr on my 1984 300d by making my own plates. Do I just need to cut a piece of aluminum info shape, drill the holes, and rtv a gasket or is it more involved? Any advice is appreciated including where to buy a prepaid kit because I looked but could not find one. Thanks.
1984 300d 132k restormod project in the works
1985 300td 300k $600 off road adventure project
1999 land cruiser  235k, 33" mud tires, off road, towing, hauler
Dark Hawk
Alec300SD
02-28-2016, 06:42 PM #2
Contact Rollguy.
http://www.peachparts.com/shopforum/dies...e-kit.html
Cash only as I recall.
Alec300SD
Contact Rollguy.
02-28-2016, 07:02 PM #3
It is as simple as what you described for the intake. For the exhaust I cut the stock flex pipe and has a friend tig weld a washer on it and just clamped it back onto the manifold. It also makes a good port for exhaust backpressure if you are interested in performance Smile
Torkey
Dirty Diesel
220
02-28-2016, 07:14 PM #4
(02-28-2016, 05:37 PM)Dark Hawk I am planning on blocking off the egr on my 1984 300d by making my own plates. Do I just need to cut a piece of aluminum info shape, drill the holes, and rtv a gasket or is it more involved? Any advice is appreciated including where to buy a prepaid kit because I looked but could not find one. Thanks.
I've got a manifold I could sell you with the EGR blocked.  It also has been ceramic coated.  PM me if you are interested.
This post was last modified: 02-28-2016, 07:16 PM by Torkey.
79 300CD
82 300SD
Dirty Little Freaks Racing
Torkey
79 300CD
82 300SD
zeeman
02-28-2016, 07:46 PM #5
Intake is just a plate bolted on and silicon as stated already. I tap the exhaust port to a pipe thread and screw in a pipe plug in. Also you can also drill and tap the pipe plug for a EGT temp sender.
zeeman
Dark Hawk
02-29-2016, 01:06 AM #6
Thanks for all the good advice! I like the variety of responses.
As for the tig method, if only I could afford a tig welder Sad love tig welding.
I will pm that guy over on peachparts, thanks for the link.
For the threaded pipe method, I like this one too and is more tangible and I really like egt temp tap idea, that's clever, easy, and clean way to do it. What size tap do I need? I don't want to buy a whole set being that I don't have much use for them and it is kind of hard to figure it out without a set on hand in my limited experience with taps.
As for the manifold, I might be interested if it's ported and polished. Otherwise I'll pass, but thanks for the offer.
Thanks for all the great responses, I appreciate it.
Dark Hawk
baldur
Fast
511
02-29-2016, 05:09 AM #7
TIG welders are ridiculously cheap out of China these days. A compact DC unit with HF start for welding steels will run about a couple hundred USD. I picked up a 250 amp AC/DC unit late 2014 for $500.
Baldur Gislason
baldur
Baldur Gislason
Tito
02-29-2016, 05:47 PM #8
I use a 200 dollar TIG welder. It hasn't let me down and is good bang for the buck. Especially for beginners like me!
Tito
02-29-2016, 10:00 PM #9
It's not a good location for the egt sensor as it is not in the mainstream exhaust.i guess it might be better than nothing, but the way I look at it is if I'm going to spend $100+ on a egt guard I'm gonna put in it the right spot haha
EmJay
03-01-2016, 06:55 AM #10
I'm more interested in the thread the EGR hole with a plug, but who knows the size? Agree, gauge close to turbo
EmJay
Alec300SD
03-01-2016, 11:38 AM #11
(02-29-2016, 01:06 AM)Dark Hawk Thanks for all the good advice! I like the variety of responses.
Best place to mount an EGT pyrometer probe is right before the turbo in the middle of the exhaust stream to get accurate temps.
A blocked-off EGR port does make an excellent place to mount an probe to monitor exhaust pressure.
The tap needed depends on the probe you use. Ceramic coating is nice. Porting is probably not needed. For a clean look nothing beats an early non-EGR manifold setup.
My 78 W116 300SD came with non-EGR exhaust and non-EGR intake manifolds.
Installed the spare ceramic coated exhaust manifold back in 2014 (more photos and write up in link on post 46 and 47).
http://www.peachparts.com/shopforum/dies...300sd.html
Just sold my original non-EGR exhaust manifold to a forum member.
Still have the original non-EGR intake manifold (log-style) mounted on the car.
That intake manifold will be available for purchase later (cheap).
Next step, preparing and installing the W115 long runner intake to allow for an intercooler and piping.
Intercooler and piping to come after new Dieselmeken 7.5 mm elements for MW pumps are available.
(Coming in a few months as per his 2-23-2016 Facebook post Big Grin ).
Sorry about the large photos. Click on them, then select 'Open image in new tab' to see a more manageably sized photo.
Alec300SD
03-01-2016, 01:12 PM #12
I have a complete P&P head and manifold set that I would think about letting go. I would even block off both egr ports for you.
The way I block off the exhaust side is completely cut the egr port off of the Manifold and weld the port shut, because if you are planning on going with a larger turbo the intake will hit the egr port. Plus it looks nice Smile
This post was last modified: 03-01-2016, 01:16 PM by MFSuper90.
zeeman
03-02-2016, 08:06 PM #13
I used a 3/4" pipe tap, the castings vary some so you may have to take a die grinder and round out the hole for the tap. It doesn't seem to affect the temperature very much in that location.
The problem is that the sender probe is long and doesn't fit well anywhere else.
zeeman
Dark Hawk
03-05-2016, 03:15 PM #14
I'm just going to fab up my own kit and save a few bucks. I'll get around to it once I order my egt gauge.
Dark Hawk
AlpinaM30B35
03-05-2016, 08:57 PM #15
For the 603 manifold a dorman 21mm freeze plug works perfectly to plug the EGR hole
http://imgur.com/E9SVNb7
AlpinaM30B35
03-06-2016, 06:03 PM #16
Good advice here on EGT probe, has to be in the path of the fire.
For the EGR, just unplug it-it looks like crap that way but doesn't cost anything Tongue
Dark Hawk
03-07-2016, 04:50 PM #17
This ain't Africa lol
Dark Hawk
Dark Hawk
03-07-2016, 04:55 PM #18
Wait what material is the factory header, iron? If it's steel I could just weld a plate over the exhaust portion.
Dark Hawk
03-07-2016, 06:59 PM #19
It's cast iron. I've successfully MIG welded cast several times, or you can braze it.
03-08-2016, 06:34 PM #20
(03-07-2016, 06:59 PM)MFSuper90 It's cast iron. I've successfully MIG welded cast  several times, or you can braze it.
x2 it's good metal, just preheat the crap out of it(charcoal grill), weld it, then put it back on the grill with the lid closed and let it cool down over several hours the first time.
Also hammer the weld right after you zap it.
AlpinaM30B35
03-09-2016, 11:28 AM #21
I welded the euro 603 cast exhaust elbow to a 2.5" stainless v band without issue. Prepped it well, minimal preheat, 1/8 sharpened 2% thoriated, #7 gas lens at 12CFH, 309 filler
Worked great
AlpinaM30B35
Worked great
Dark Hawk
04-13-2016, 09:18 AM #22
Made it! The intake manifold block off is a bit ugly but seems to function fine, I'll know for sure once my boost gauge is installed which I'll do later today. I made it like I said it would in my first post in this thread.
I have the exhaust porting bandaided for now, until I get a pipe tape and die which seems to be the best option for what I want to do.
Dark Hawk
 3 Guest(s)
 3 Guest(s)
