STD Tuning Engine Om 603 - 606 Engine Angle
zeeman
03-21-2016, 02:09 AM #1
Anyone know if the 603 and 606 engines sit at the same angle. The 606 seems to be setting at about 15 degrees. I bought a GM transmission to 603-606 engine adapter from a company and when the transmission pan is level the engine oil pan and valve cover are not. Thought maybe the adapter was made to a 603 and the angle was different.
zeeman
hooblah
03-21-2016, 04:16 AM #2
The 606 sits at an angle. The sump and engine cover should be sitting parallel to the ground. The 722.6 that came bolted to them from factory has the correct orientation and sits level. My 6 speed is also slightly off. I guess that's just the way it is.
hooblah
TurboTim
03-21-2016, 08:04 AM #3
As far as I know they sit at same angle and use same mounts.
76 300TD custom lots of stuff
TurboTim
benzguy
03-21-2016, 09:05 PM #4
The Block is the same and like turbo Tim same mounts I swap the 606 for a 603 in a 95 E300 I use all accessories from the 606 on the 603
benzguy
zeeman
03-22-2016, 12:27 AM #5
(03-21-2016, 09:05 PM)benzguy The Block is the same and like turbo Tim same mounts I swap the 606 for a 603 in a 95 E300 I use all accessories from the 606 on the 603
Thanks that answers my question if they are the same.
zeeman
