STD Tuning Engine Best 603 pump to modify?
mike89011
05-25-2016, 12:26 AM #1
Hey All,
I'm new here, and am going to be "superpump"-ing a 603 pump, for use in an OM606-- with some help from Sweden!
My question in purchasing the pump to be modified, is if there is a specific year or model of pump I should look for, that is considered the best?
Since cost is basically the same, why not purchase the one with the best features, or greatest durability, compared to the others?
Or is it all the same, once they get the larger elements?
Thanks so much!
mike89011
Hey All,
Thanks so much!
EvoPeter
05-25-2016, 01:06 AM #2
RS174 or above for om603 pump if u want 8mm element i heard from some pump builders.
EvoPeter
50harleyrider
GTA2359VK
397
05-25-2016, 05:03 AM #3
What horsepower are you looking for? I let Dieselmeken supply the pump and that way I knew I getting the best bang for my $. PM me- I might have some stuff you want.
50harleyrider
EvoPeter
05-25-2016, 06:44 AM #4
(05-25-2016, 05:03 AM)50harleyrider What horsepower are you looking for? I let Dieselmeken supply the pump and that way I knew I getting the best bang for my $. PM me- I might have some stuff you want.
I would recommend a Herlevi pump. Had a Dieselmeken last year. But if you dont want to put all the money into the pump go for Dieselmeken.
EvoPeter
soltysrsz
05-25-2016, 08:03 AM #5
Hey all, which ip would be better to modify:
-PES 6 M55 C320 RS175-1, old sections was replaced by 6mm sections
-PES 6 M55 C 320 RS181
I'd like to install 7,5mm sections. One off this pump will go to om606 offroad car with standard turbo, another one will go to car with holset h1c, or bigger turbo Smile.
Mercedes W123 240D (om616->om606)
Audi A6 C4 2,8 Quattro (AAH)
EX Audi 80 Competition
EX Ford Scorpio 2,9 4x4
soltysrsz
mike89011
05-25-2016, 08:25 AM #6
I'm not looking for a black smoke demon, only for around 300hp, so was going to go with the 7.5mm elements.
And I would have let Dieselmeken supply the pump, but he is all out right now!
mike89011
50harleyrider
GTA2359VK
397
05-26-2016, 06:44 AM #7
PM sent
50harleyrider
PM sent
