STD Maintenance General Locked out of boot with disconnected battery help!!!
LewisG95
07-05-2016, 02:52 PM #1
Hi,
I have managed to lock myself out the boot. The battery is disconnected and the key for the boot does not work. I do have access to the engine bay and cabin.
I have tried doing the trick with the little black outlet box next to the fuse box but that doesn't seem to be working.
Any help would be much appreciated.
Thanks
LewisG95
Hi,
Thanks
erx
w202 om606
323
07-05-2016, 03:03 PM #2
If you have battery terminal under the bonnet then connect your battery there.
erx
M-ic
W201 OM605/722.6 fully electronic
15
07-21-2016, 01:28 PM #3
What kind of car? If its a 124, 201 or 202(obviously not a 210 since the battery is in the cabin), you can unhook the vacuumpipe to the rear lid under the backseat, and yes, suck it! That will open the lock....
M-ic
