STD Tuning Engine Part NR om606.962 starterwheel/flywheel.
-Mackan-
07-07-2016, 04:53 AM #1
Hello would Some one mind sharing Some partnumber info of the 606 turbo flywheel "flexplate"
Also if the same flywheel is bolted up to other engines and cars Smile
/Markus
Cars currently owned:
1993 Mercedes Benz 300TDT W124
1992 Mercedes Benz 500E W124
-Mackan-
/Markus
zeeman
07-08-2016, 11:28 AM #2
(07-07-2016, 04:53 AM)-Mackan- Hello would Some one mind sharing Some partnumber info of the 606 turbo flywheel "flexplate"
/Markus
There are some similar flexplates on other engines, but the diesel is double thickness. The others are single thickness.
zeeman
/Markus
EvoPeter
07-11-2016, 05:44 AM #3
You need a dualmass with flex? There is solid dualmass from sprinter that fits. A brand new cost 300euro from Germany with shipping to Sweden.
EvoPeter
-Mackan-
07-11-2016, 04:52 PM #4
Hi guys im looking for one for the 722.6 auto Smile
-Mackan-
pryantcc
07-13-2016, 09:15 AM #5
Hi,
Mine has A606 030 0112 stamped on the ring gear. There's nothing anywhere else on it. I'm not sure if this is the part number for a new ring gear only or for the whole plate?
[Image: photo_zpshq6hjv2h.jpg]
1992 W201 190D 2.0L and 1971 W108 280SE with OM606, electronic pump and 6 speed manual gearbox.
pryantcc
Hi,
50harleyrider
GTA2359VK
397
07-13-2016, 10:04 AM #6
dual mass applies only to manual flywheels, EvoPeter. That's probably why you noticed.
This post was last modified: 07-13-2016, 10:06 AM by 50harleyrider.
50harleyrider
-Mackan-
07-13-2016, 02:03 PM #7
Thx a bunch!!
-Mackan-
Thx a bunch!!
