STD Tuning Engine Results of my HE351VE.....
  • 1 Vote(s) - 1 Average
TurboTim
07-29-2016, 06:44 PM #1
The turbo looks nice and everything looks like it was well done. They even machined the silencer ring so it looks more like a ported housing.  Now for the results...
So I am open to ideas. Still only 30psi. My thoughts are I am burning all my fuel or exhaust maybe too restrictive at full 3 inch. My pump says 160cc on it and is turned up all the way. Not sure where I should go at this point. Sell off turbo and go HX52 or try 4 inch exhaust. I may also try messing with my cams because I do have bigger cams and I think advancing them may help a bit. Im going to keep testing and trying. I will read EGP after the turbo and see. If its a bunch I will go full 4 and see if that helps.  I may try dropping half of it and see if that help.
76 300TD custom lots of stuff
TurboTim
Duncansport
07-29-2016, 09:56 PM #2
I'm seeing about 38 PSI max on my 605 with 150cc fuel.
Duncansport
TurboTim
07-29-2016, 10:24 PM #3
What is your setup?
TurboTim
What is your setup?
Duncansport
07-29-2016, 10:35 PM #4
(07-29-2016, 10:24 PM)TurboTim What is your setup?
HE351CW, long tube header, ported wastegate. Not sure is the gate is creeping open limiting my boost or i just dont have enough fuel
Duncansport
[486]
07-29-2016, 10:53 PM #5
Give us some data other than "still only 30 psi"
EGT, amount of black smoke while at full boost, the exhaust manifold pressure when you're making 30 PSI in the intake
are the ones I'd call the most useful in telling you what you need to do next
[486]
seanyt
is300d He351ve
279
07-30-2016, 02:29 AM #6
What's exhaust pressure like with it now.
Even forcing veins closed more won't build more boost now?
Also has spool changed much with new turbine
This post was last modified: 07-30-2016, 02:31 AM by seanyt.
seanyt
TurboTim
07-30-2016, 07:56 AM #7
(07-29-2016, 10:35 PM)Duncansport
Not really the same turbo.
TurboTim
TurboTim
07-30-2016, 08:12 AM #8
(07-30-2016, 02:29 AM)seanyt What's exhaust pressure like with it now.
Its hard to tell if spool changed since it has been so long.
Forcing vanes closed more just backs up system and makes less boost and just higher EGP.
Maybe I am just burning all my fuel. Its a 160cc pump or at least that is what its stamped with.
TurboTim
07-30-2016, 08:38 AM #9
What's egts? And does it smoke at WOT
TurboTim
07-30-2016, 08:42 AM #10
EGT's are at 700 to 750c as far as I can tell not much smoke under boost.
TurboTim
JVance
07-30-2016, 10:08 AM #11
(07-30-2016, 08:42 AM)TurboTim ...as far as I can tell not much smoke under boost.
You're out of fuel.
JVance
You're out of fuel.
TurboTim
07-30-2016, 10:22 AM #12
Anyone want a good deal on an 8mm injector pump then?
TurboTim
seanyt
is300d He351ve
279
07-30-2016, 12:20 PM #13
Surely 160cc is plenty of fuel for this turbo.
seanyt
TurboTim
07-30-2016, 12:35 PM #14
(07-30-2016, 10:08 AM)JVance
You're out of fuel.
Not according to this guy Wink
TurboTim
You're out of fuel.
seanyt
is300d He351ve
279
07-30-2016, 12:42 PM #15
Some notes from muuris also an om606 he351ve
He351V/OM606
-38mm wg, 110cc IP setting, 3,5" dp, 3" exhaust, 1,8bar boost, (backpressure not listed), 381hp
-46mm wg, 130cc, stiffer valve springs, electric fuel pump, 2,5bar boost, 3,0bar backpressure, 390hp
-same as previous, 2,4bar boost, 2,8bar backpressure, 396hp
-150cc, full 3,5" exhaust, 2,0bar boost, 2,8bar backpressure, 388hp
-130cc, 2,0bar boost, 2,8bar backpressure, 402hp
seanyt
He351V/OM606
seanyt
is300d He351ve
279
07-30-2016, 12:43 PM #16
It does sound like your out of fuel but maybe not using
The full 160cc. What's it revving to?
seanyt
TurboTim
07-30-2016, 12:50 PM #17
6k to 7k the hp stays pretty much same.
TurboTim
TurboTim
07-30-2016, 10:09 PM #18
Maybe Dieselmeken set mine up to not put out as much fuel up top since I had a 603 at the time.
TurboTim
NZScott
HX30W 73/44mm
398
07-31-2016, 01:10 AM #19
Dieselmekens "older" elements need like 40 psi to work full output at high rpm, do you know what your fuel pressure is?
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
CRD4x4
CompoundSuperTurboDiesel4x4!
399
07-31-2016, 07:18 AM #20
(07-30-2016, 10:22 AM)TurboTim Anyone want a good deal on an 8mm injector pump then?
PM me if you're serious. A "good deal" is what I'm looking for. Maybe even trade if.
CRD4x4
erx
w202 om606
323
07-31-2016, 07:31 AM #21
(07-30-2016, 10:09 PM)TurboTim Maybe Dieselmeken set mine up to not put out as much fuel up top since I had a 603 at the time.
Is ALDA max fuel screw turned to max position? Is it smoking when 2bar?
erx
07-31-2016, 07:47 AM #22
I would say something with your fuel is lacking. 700c is not hot, and if it's burning fairly clean I'd say it's out of fuel. 160cc is a fair amount, but not a lot. Have you confirmed its at full fuel?
Have you tried throwing more timing at it? That will put some more heat into it
This post was last modified: 07-31-2016, 08:03 AM by MFSuper90.
TurboTim
07-31-2016, 08:46 AM #23
Yep ALDA is maxed and fuel screw is also. I did take the back cover off at one point when I was trying to raise the rev max gov RPM to 7k. I did what Goran said but sometimes he isnt the most clear all the time. Maybe I need to mess with tq control capsule?
TurboTim
TurboTim
07-31-2016, 08:47 AM #24
(07-31-2016, 07:31 AM)erx
(07-31-2016, 07:47 AM)MFSuper90 I would say something with your fuel is lacking. 700c is not hot, and if it's burning fairly clean I'd say it's out of fuel. 160cc is a fair amount, but not a lot. Have you confirmed its at full fuel?
I think my EGT's are so low because I was spraying nitrous at the same time.
TurboTim
hooblah
07-31-2016, 08:58 AM #25
What's your emp at 30psi?
hooblah
TurboTim
07-31-2016, 09:39 AM #26
Pretty close to 30
TurboTim
Pretty close to 30
07-31-2016, 11:10 AM #27
(07-31-2016, 08:47 AM)TurboTim
That could be it. The laughing gas will do funny things
TurboTim
07-31-2016, 12:24 PM #28
Has anyone personally experimented with a wideband on diesel or even a cheap narrow band?
TurboTim
TurboTim
07-31-2016, 12:26 PM #29
I looked yesterday when accelerating and its hard to say but at 80mph there isnt a lot of smoke....really just a hint.
TurboTim
TurboTim
07-31-2016, 02:02 PM #30
Well I turned my the torque control capsule to the point of run away and turned it back about half turn. I think it was about 1.5 turns total. Will report back with what happens.
TurboTim
07-31-2016, 03:26 PM #31
got litle to do with the element , old vs new ...
after 4500engine rpm , superpumps need some extra´s like main galery presurization, and so on... a 160cc pump at 1000 pump rpm might not deliver 160cc at 3000 pump RPM unless force feed...
but i dont think that is the problema of turbo tim , it might well be the set up , or some simple thing as a leak ...
but anyhow having 2 bar in a single set up , is not that bad...
TurboTim
07-31-2016, 03:36 PM #32
Woohoo! 38psi! It also smokes way more at part throttle witch is weird. Shall I try turning up max fuel now also?
TurboTim
TurboTim
07-31-2016, 06:08 PM #33
Woohoo! 38psi! It also smokes way more at part throttle which is weird. Shall I try turning up max fuel now also?
TurboTim
TurboTim
07-31-2016, 06:09 PM #34
I should also mention since someone asked....fuel pressure is 10psi and goes up on 1 to 1 under boost so should be roughly 48 psi.
TurboTim
seanyt
is300d He351ve
279
08-01-2016, 01:46 AM #35
Videos or it didn't happen haha.
Good progress, worth a dyno run soon.
seanyt
ProjectNotSlow
02-27-2021, 12:45 AM #36
I know this is old but I had hx35 not building much boost took the turbo off a few times and looked for boost or exhaust leaks took a month to find out it was my fuel filter needed replacing. After new filter 38psi and breaking tires loose at 50mph.
ProjectNotSlow
