STD Tuning Engine Om 606 Timing Marks Gone
zeeman
08-04-2016, 03:03 PM #1
In pressure washing these engines with purple cleaner, I have found the timing marks come off the balancer. They are painted on and are removed when pressure washed. Besides marking them from another balancer is there any decal out there for this? Anyone?
This post was last modified: 08-04-2016, 03:04 PM by zeeman.
zeeman
baldur
Fast
506
08-04-2016, 07:19 PM #2
if you measure the diameter it's easy to make a decal that's accurate. All you need to do is find TDC to place it.
The spacing between each degree line is the diameter of the damper times pi divided by 360.
This post was last modified: 08-04-2016, 07:20 PM by baldur.
Baldur Gislason
baldur
Baldur Gislason
