STD Tuning Engine OM605 manual pump + oil cooler
Nev
09-22-2016, 04:50 PM #1
Good evening, this is my first post so hello everyone!
I'm building a W124 with a 605 at the moment and i've got a question about oil coolers. I'm using a KKK turbo from an E300 so i'm not going to be making huge power. Obviously the 605 comes with the oil/water cooler, but with the manual pump on this won't fit. I have a 606 n/a oil filter housing which does fit but this means I don't have an oil cooler.
What is the best way to get round this? So far i have 3 options;
  • 606 n/a housing and no cooler (probably overheat the oil)
  • 605 housing with fittings welded on in place of the standard oil/water cooler (with there being no thermostat on it, could this cause warm up issues with the oil?)
  • Make a sandwich plate, remote oil filter and cooler (pain in the a*se)
any other suggestions? Here's a photo of my car and the engine before i put it in yesterday!
[Image: 14359080_10157338011295276_3162859479113...e=5885C2F8]
Thanks!
This post was last modified: 09-22-2016, 06:20 PM by Nev.
Nev
Thanks!
Mallinman
09-23-2016, 01:25 AM #2
Is it a dieselmeken pump you've got on?? Cos that's what I've put in mine and the oil/water cooler has fit on.
Mitsubishi L200 manual om605
7.5mm Bosch 044 fed pump
Borgwarner S200
Mallinman
Borgwarner S200
Nev
09-23-2016, 01:38 AM #3
Its from Luke at DieselPumpUK. If I took the rear module off it and made a plate it would fit, but as it is it doesn't.
Nev
Mallinman
09-23-2016, 10:17 AM #4
(09-23-2016, 01:38 AM)Nev Its from Luke at DieselPumpUK. If I took the rear module off it and made a plate it would fit, but as it is it doesn't.
Yea mines from Luke. But it does fit. Well it's all in anyway. It is close tho. Il take a pic.
Borgwarner S200
Mallinman
Borgwarner S200
Mallinman
09-23-2016, 03:27 PM #5
Ok I can't figure out how to put a pic up. I could what's app it to u if u gave me ur number.
Borgwarner S200
Mallinman
Borgwarner S200
09-24-2016, 01:35 AM #6
Search for the part # A606 180 03 34 , attaches to the filter with the proper hose connections. Compatible with filter supports in any MB with the cooler.
regards
regards
11-02-2016, 11:46 AM #7
606.962 filter housing with remote oil cooler take off already built in?
