STD Tuning Engine cdi injectors
cdi injectors
cdi injectors
bmartins
10-09-2016, 03:01 PM #1
Hello.
Does anyone know best part number injectors for a 270 cdi engine?
And a Common rail valve able to hold a bit more pressure???
Thank you
bmartins
Hello.
Thank you
Turbo
10-11-2016, 11:32 AM #2
what do you mean with "best part nr"
Turbo
bmartins
10-22-2016, 04:00 PM #3
Hello.
I need to know if anyone knows which reference of injectors should i buy to get my 270 cdi running fine?
For example somenone told to buy A6110701687 from a Sprinter one...i guess better flows...right?
bmartins
Hello.
starynovy
10-23-2016, 05:12 AM #4
What? To run fine you stick to what you have and have them remanufactured since original 15yo injectors pass so much fuel along needle that you wont be runing even stock power. If you want more then tell manufacturer you want to incrase full load delivery-this can be done by grater master needle lift and/or fitting larger nozzles from AMG OM612. This will require remap either way as it ill overfuel and smoke.
starynovy
