STD Tuning Engine Options for elements for OM606
TurboTim
10-26-2016, 05:56 AM #1
What are the best elements these days? Still Goran's 8mm ones? Or does Myna sell better ones?
76 300TD custom lots of stuff
TurboTim
Evgeniy1987
10-26-2016, 10:43 AM #2
I thought, people here often say that the 7.5 Göran's run better because the 8mm run harsch ?
Evgeniy1987
awsrock
300SDL / HX30 / 90cc
179
10-26-2016, 04:26 PM #3
Herlevi also makes their own 8mm, but not sure how they compare to others.
awsrock
50harleyrider
GTA2359VK
397
10-27-2016, 04:44 AM #4
What about for the oe electronic injection pump? I'm planning on using Baldurs' ecu on my build so want to keep it. Is the only viable option to send it to Dieselmeken for larger elements?
50harleyrider
starynovy
10-27-2016, 05:05 AM #5
Well no.. EDC pump does not require complex governor setting as it does not have any. Any diesel shop which service inline pump will do the swap. Its just balancing delivery and synchronising timing nothing else. Of course this is the easy part, tuning voltage map so it iddles is another story and not every chiptuner can make it work as majority just pours pre-tuned files into ECU without even knowing in depth.
starynovy
TurboTim
10-27-2016, 05:48 AM #6
Where is this Herlevi brand? I have mechanical Goran pump now and am moving to electronic for better control.
TurboTim
awsrock
179
10-27-2016, 12:55 PM #7
Herlevi is Finnish, they have a website herlevi.fi I think. Google will get you there
awsrock
