STD Tuning Engine 270cdi, boostsensor, amg injector,chip/map,,,,
tgg416
11-21-2016, 01:16 PM #1
Hey, can anyone advice me a litle,,
I have a 2004 G class with 270 cdi engine, 156 hp.
I wonder to chip tune it or re-map it.
But first maybe change injectors to AMG C30 injectors ?
Plug the EGR and maybe change the boostsensor from 3 bar to 4 bar? Will this trick the engine to boost more ?
Later maybe change to turbo from 320cdi ?
Lots of question here, thanx for helpful info
Gwagen 463, 270cdi
tgg416
Gwagen 463, 270cdi
hents99
11-24-2016, 03:14 AM #2
Make strong tune. It helps a little. But this engine is weak for g-wagen anyway.
hents99
starynovy
11-26-2016, 05:43 AM #3
With right mods it will make smooth 200kW/600Nm so I doubt its that weak, surely not compared to laggy 606 with truck turbo.
starynovy
11-26-2016, 08:44 AM #4
Its week , i know that in first hand...at least in the 612 engine family
The rod bearings tend to rotate, not only in the 612, but the 611 too(613 should be too) valves springs are week in the intake side,
Head gasket burns easily, but that can be corrected , injector wells leak , HP pump is not suited for too much output, cooling system small,
and some other smalish things , but a 612D29 is a diff story....
starynovy , one question u use to tune this electronic things , how do u manage to keep the EGP under control once the EGR is disabled? or u dont disable EGR?
thanks.
thanks.
tgg416
11-26-2016, 03:00 PM #5
Thank you for info.
Im probably getting amg c30 injectors from dieselmeken soon and then a mapping togheter with another boost sensor I guess.
170-185 kw will be enough if its safe for this engine.
Its possible to buy chip that promise about 160 kw, but I feel chip is not as good as mapping and other injectors ?
Im not shure whats my engine code is, my vin is WDB4633231x146238.
Is it any way to secure the rod bearing ?
Thank you for your input barrote. Do you think my kw goal is reachable without taking the engine apart ?
Thanx for all help.
Gwagen 463, 270cdi
tgg416
Thank you for info.
Thanx for all help.
Gwagen 463, 270cdi
11-26-2016, 11:24 PM #6
It had happened to me, in a almost stock engine , around 400000, with some abuse, but car is AUTO so what kind of abuse can u give to a auto car.
its possible so lock the bearings "old way" but if the problem is oil suplly, and egocentric movement of the rod, what can u do, rods need atention... and those are that kind where they make them in a single piece and then brake it with cryogenic technick, dont seem to strong...
the gasket goes by overheating, and so on...
starynovy
11-28-2016, 05:11 AM #7
I dont know, we are making realiable 290PS from stock 611 with lowered compression. Fuel system is overhauled and runs 1700Bar. Maybe you had bad luck but I would never call inline common-rail weak or prone to failure. EGP is managed with opening of turbocharger vanes, I dont understand what do you mean with EGR-off course it is disabled, same as swirl flaps.
starynovy
11-28-2016, 05:37 AM #8
Explain, CDI engines can swallow as much as 60% EGR , no doughts about that, expecially in the high fueling phase...
one problem i faced was too huge EGP with a GT23, even with vanes totally open, (in a 605) specially above 4.5k, one solution i found was to dampen some EGP out the EGR valve and it helped about 50hp and a lot more in high revs, but then the turbine quit , vanes turbine bearings everithing melt, back to design table, gt 23 repaired , but now i moved to sequential set up .... so i´m dampening the extra gas same way but is working in the big boy...
Its not working near perfect but, i belive the problem relies in the GT23 repair than the set up....
so in the 612/13 what do u experience(EGP) when u switch of the EGR, where are this mass flow goes, it flows through the turbine without problems ?(high EGP)
MartinB
OM605 Power
154
11-28-2016, 01:55 PM #9
Soon i will measure EGP on my OM611 with GT2364V. I am using 2.2+bar boost and think EGP will be good. GT23V is far too small for high rpm´s in OM605.
W210 E200CDI 185kW Manual, W203 C30 CDI AMG 210kW Manual
MartinB
11-28-2016, 02:44 PM #10
curious, where did u get the 2364V, i used to have a 2359 out of a 613.
yours should have a improved compressor , and ball bearing right?
For my setup i never had troubles since i got it bleeding some extra gas, boost remains in the 2 bar area or above, and then i wonder how it would behave in series with a big boy. works well but not that well
improvements are on the way...
MartinB
OM605 Power
154
11-28-2016, 02:49 PM #11
GT2359V from OM613 with 11b billet extended tip compressor wheel. I have photo in my own thread.
MartinB
11-28-2016, 02:56 PM #12
hhaha thats why u call it 64.... i have that too, mine is somewhat 63 the boy at the shop told me, he also said there´s a wider one like 66 or 68 , but it might be too laggy.
i belive mine stalls around 2 bar , engine shakes , but i never payed too much atention to it , maybe is the clutch or something else complaining ... once we start doing this matters , there are complainta everywhere....
MartinB
OM605 Power
154
11-28-2016, 03:03 PM #13
I have fast response with almost zero lag. In peak have 2.5bar and no problem.
MartinB
11-29-2016, 03:06 AM #14
yes , numbers match , despite u have a DI engine and i have pressure based control on konstant boost press.
how do u have your control set ? do u use konstant MAP , as far as i know the 611 uses a gt20WG , if u use the ECU , could u explain the map parameters .
MartinB
OM605 Power
154
11-29-2016, 05:01 AM #15
I have W210 FL. Original turbo is GT1852V. WG was on older model. Original MAP is up to 1.5bar boost, there is up to 3bar boost.
MartinB
11-29-2016, 07:44 AM #16
ok ,
got it so u have something between the 611 and 646, right ?
anyhow the VGT maps have many parameters , they are not meant to produce max boost at any time, so the million dollar question for me, of course how did u change that to 3bar , just made a convention of the 1.5 bar? makes sense since u only want it to build boost right?
sorry my too many question , but i´m wondering around too many ideas ...
ok ,
MartinB
OM605 Power
154
11-29-2016, 08:30 AM #17
No. This is original W210 with VNT turbo like OM612 or OM613 - same type engines.
MartinB
11-29-2016, 09:58 AM #18
ok martin , i got it , in my country 611´s are gt20´s WG , 646´s gt18´s vnt.
i understand now why u did not need any modification, but how did u made it go over 1.5 bar?
MartinB
OM605 Power
154
11-29-2016, 10:50 AM #19
You have to change it in ECU. You can simply google it. But that is one thing from thousand what you should change.
MartinB
