STD Tuning Engine Om617a head porting?
  • 1 Vote(s) - 4 Average
Evenglass
12-18-2016, 08:25 PM #1
So I'm about to pull the head on one of my engines while I'm there I figured might as well do a small port and pollish job. Has anyone done this? What kind of results can I expect?
Evenglass
12-19-2016, 11:57 AM #2
I ported my head and stock manifolds, the engine ran fine on a stand but it's still yet to go into a car.
The head stands to gain from inside the turn just behind the valves. don't cut too much or you're into the water jacket.
Don't go too crazy on the outside of the head unless you plan on hogging out your manifolds to match.
Budget a couple hundred and get new valve stems pressed in and the valves ground while it's out-that made a huge difference in smoothness.
As for the manifolds, the stock turbo manifold is poorly cast-there are big lumps inside that you can easily remove. Once it's apart it will be obvious.
Polishing is a waste of time, just finish it off with ~200 grit and she's good to go.
Evenglass
12-20-2016, 06:14 AM #3
(12-19-2016, 11:57 AM)Simpler=Better I ported my head and stock manifolds, the engine ran fine on a stand but it's still yet to go into a car.
Thank you for ththe reply.
Evenglass
Hercules
12-22-2016, 12:24 AM #4
Install new seats. Valves usually seat to low in head,seriously shrouding air flow. Max. valve protrusion out of head is .007 thousands,stock head. what ever amount
head is surfaced subtract this from stock amount.Best is valve head flush or nearest to head surface.
Second,mod head in valve area.  Taper back the head material just out side the valve,remove more at center of cyl. head tapering to less nearest to next cyl,.
Do the same on the head nearest pre chamber,but cut less,not as much fuel burn on that side. Do not need to remove much.
This is on a article on the forum,diesel performance head mods.do not remember where. Surprised this is not used more often
Works very well,the article states 20-25 h.p. or more. Yes I did this,better performance plus 3-5 m.p.g.better.  Big Grin
Hercules
kestreltom
12-23-2016, 01:01 PM #5
(12-22-2016, 12:24 AM)Hercules ... Taper back the head material just out side the valve,remove more at center of cyl. head tapering to less nearest to next cyl,.
Are you talking about grinding in the combustion chamber area? What about compression, cold starting, etc.?
Is this the article you were talking about? (see links on Deliveryvalve's post #4)
This post was last modified: 12-23-2016, 01:21 PM by kestreltom.
kestreltom
Evenglass
12-23-2016, 08:24 PM #6
(12-22-2016, 12:24 AM)Hercules Install new seats. Valves usually seat to low in head,seriously shrouding air flow. Max. valve protrusion out of head is .007 thousands,stock head. what ever amount
Those are great results! I am a little lost when trying to figure out where the areas you stated are on the head.
Evenglass
12-24-2016, 03:27 PM #7
In the ports, remove more on the manifold side than the injection pump side is what he's talking about
Hercules
12-24-2016, 11:34 PM #8
Yes Kestreltom that is the article on head mods. Unshroud the valves,combustion chamber mods.  Do not worry about compression loss.
  Took me about 20min. with a drill and grinding bit.Do not need to remove lots .  My old 82 300sd has 720 thousand miles ,starts quickly in freezing temps,
 28 degrees F. will start before glow light out. Engine is a bit tired but will pull a grade of 6-8% in top gear,85 plus temps.7500 ft.above sea level
and still have a little left,long hill,6-7 miles upgrade,70 m.p.h.  High desert so a bit dry also.
 This mod. was done at about 640 thousand miles,down and dirty.  Head gasket let go,pull head,clean-up,ck surfaces do mod.reinstall.
Would have been a great time to do a good valve job.   No time!!!!   So did not do any porting of intakes,did not install new valves and seats.
Valves were seating low in head, Most are Factory to you,but I did unshroud them a small amount, what a differance,glad I did.
Hercules
Evenglass
12-24-2016, 11:47 PM #9
(12-24-2016, 11:34 PM)Hercules Yes Kestreltom that is the article on head mods. Unshroud the valves,combustion chamber mods.  Do not worry about compression loss.
Can you explain unshrouding the valves? is this done on the combustion chamber sides? wouldn't happen to have pictures?
Evenglass
Hercules
12-25-2016, 06:45 PM #10
(12-24-2016, 11:47 PM)Evenglass
The valves in these engines seat low,below head surface,the head material just above shrouds the valve and interferes with good air flow.
Kestreltom has given a link to where at on the forum this article appeared. Go there then look up on internet for the main article,good clear
pictures and good read. No need to go this extensive.
Hercules
Evenglass
12-25-2016, 08:57 PM #11
(12-25-2016, 06:45 PM)Hercules
Thank you!
Evenglass
Thank you!
kestreltom
12-26-2016, 08:48 AM #12
(12-25-2016, 06:45 PM)Hercules The valves in these engines seat low,below head surface,the head material just above shrouds the valve and interferes with good air flow.
Wow... a 25 hp increase. That is very impressive for these old engines. Indeed the 617a needs all the fluid flow improvement it can get, so this makes sense. Glad to hear that the mod does not adversely affect cold start behavior. Thank you Hercules!
kestreltom
12-26-2016, 09:40 AM #13
Oh yeah, the stock head and manifolds flow like crap.
When you really look into the stock turbo exhaust manifold it's crazy small due to casting errors.
Hercules
12-26-2016, 01:44 PM #14
(12-26-2016, 08:48 AM)kestreltom
No need to go wild ,only cut mine back at the widest 3/16" inch.  High mileage Engine. The wife was driving the car to work 400 hundred miles away,she
called  What did you do to the car? It"s not the same car,drives great,have you done any thing to the fuel gauge? Noticeable fuel mileage increase.
 This mod. does work,how much can we take take off??????  Good luck
Hercules
Evenglass
01-23-2017, 10:15 PM #15
Well this is what I came up with. This is the exhaust port before and after.
[Image: JiQhqx.jpg][Image: XZVwto.jpg]
Evenglass
Evenglass
01-23-2017, 10:18 PM #16
Before and after.
[Image: plkEPtLmj][Image: poIYrptDj]
Evenglass
Before and after.
Evenglass
01-23-2017, 10:36 PM #17
Evenglass
Hercules
01-26-2017, 02:19 PM #18
That should give noticeable improvement . The head area just under the exhaust valve,best to have some taper,speeds up air flow,to help with
quicker boost.. The head is fairly thick,the area beyond the taper in the runner as it makes the turn could IMO could be opened and rounded
a bit more. I cut a head up just to see. Same can be done on the under side of intake. Remember to leave most of the taper,open some and
round below as the opening turns towards the runner.
Please posts results.
Hercules
Evenglass
01-26-2017, 09:25 PM #19
(01-26-2017, 02:19 PM)Hercules That should give noticeable improvement .    The head area just under the exhaust valve,best to have some taper,speeds up air flow,to help with
Thank you for the response. I did not change the taper just under the exhaust valve, I just smoothed the sharp casting edge on it. I hope this was ok. This is as far as I'm going with porting, just going to smooth with some sanding next. Is gasgasket matching worth the effort?  I will keep you posted. This was a very hot debate in the STD Facebook page.
Evenglass
Hercules
01-26-2017, 11:54 PM #20
Actually the intake manifold should be about 1/16" smaller at exit than head opening,helps slow down back air pulse when valve is closed,
 disrupting good air flow.  The reverse holds true of exhaust manifold,it should be larger than exit of head,for same season,so say racing
 experts,and I do agree.    If port matched  Ok  just did not get the extra bit of performance.
How bad can the back pulse get?  On the 240d you can feel the pulsing of  air at the  intake on front of car, at idle,really slows air speed greatly.
Hercules
Hercules
01-27-2017, 12:04 AM #21
(01-26-2017, 09:25 PM)Evenglass
All is good.  The port runners are good on these heads,just the turns,and opening restricted areas.
Hercules
