STD Tuning Engine Ignition switch with vacuum switch into w202
addi.bigg
OM605; 7,5mm elements
94
01-17-2017, 08:33 AM #1
Fellas,
I'm keep searching but couldn't find a reliable source for ignition switch that contains vacuum switch, and bolt-on into a w202 c250TD (no immobiliser).
I've heard here that 2.0D 55kw is bolt-on but I couldn't find one here.
Anyone could make a comparison of W124/W190 2.0D ignition switch vs. w202 2.5TD, so I could have a proof whether I can buy confidently any of those with 2.0D
Thanks!
Ádám
addi.bigg
Fellas,
Thanks!
Ádám
Petar
7.5mm M pump
459
01-17-2017, 01:34 PM #2
You don't need it, use a vacuum solenoid wired into the ignition to shut down the engine. Worked reliably for me for years on my W123 (It was gas engined before, and I was too lazy to swap the ignition switch)
Petar
maxypriest
01-18-2017, 07:22 AM #3
I have the same set up as Petar - works perfectly.
maxypriest
Sultzi
01-21-2017, 03:59 AM #4
Did same thing than Petar (also in 123 old gasoline converted to om606). Just took one solenoid from 124 and used that to kill the engine, simple and works like a glove.
Sultzi
 4 Guest(s)
 4 Guest(s)
