STD Maintenance General re-timing injection pump
tony597fitter
10-13-2009, 10:49 PM #1
Due to having a catastrophic failure on my 83 300sd, I want to make sure my injection pump is still timed correctly with crank and cam.
Wanted to know how to do it? Cant seem to find much.
Thanks
tony597fitter
Thanks
tomnik
10-14-2009, 08:12 AM #2
(10-13-2009, 10:49 PM)tony597fitter Due to having a catastrophic failure on my 83 300sd, I want to make sure my injection pump is still timed correctly with crank and cam.
Thanks
for the cam timing just look at the marks cam/cam bearing support.
What kind of failure? The IP timing should not get lost except the chain jumped.
Tom
.pdf
07-115_adj_bod.pdf
.pdf
05-215_ck_adj_camshaft_timing.pdf
tomnik
Thanks
Tom
.pdf
07-115_adj_bod.pdf
.pdf
tony597fitter
10-14-2009, 08:38 AM #3
(10-14-2009, 08:12 AM)tomnik
Thanks
Tom
The vac pump broke and a piece of it got stuck in the chain and made the cam into 3 pieces. The timing chain never broke but it did take out a few slides and rails.
I have rebuilt just about everything.
I wanted to see if it had jumped a tooth or not. How do I check it?
tony597fitter
Thanks
Tom
10-14-2009, 03:12 PM #4
Drip timing. Plenty of threads on this over on peachparts and benzworld.
