STD Tuning Engine diy injector cleaning?
BoostedW124
03-27-2017, 09:59 AM #1
They are out of the car. worked fine before just want to clean them. Is it safe to spray them w carb cleaner? Suggestions?
BoostedW124
03-27-2017, 10:15 AM #2
carb cleaner is fine, anything but water is OK. Just don't scratch them up
mrfajita
03-29-2017, 09:52 PM #3
Disassemble them, soak in acetone and scrub with a chemical resistant nylon brush, then dip in ATF and reassemble. I don't know about cleaning the nozzles, on both my cars I did this while replacing the nozzles.
'77 300D, 617.912, HY35 15psi, 3" side pipe, maxed out stock MW pump (Sold, now converted into a ute)
'87 300TD, 603.960, questionable mods from the PO including a ghetto 3" straight pipe
mrfajita
Mallinman
03-30-2017, 04:12 AM #4
Do you need to re test the pop pressure when you put new nozzles in???
Mitsubishi L200 manual om605
7.5mm Bosch 044 fed pump
Borgwarner S200
Mallinman
Borgwarner S200
03-30-2017, 08:41 AM #5
(03-30-2017, 04:12 AM)Mallinman Do you need to re test the pop pressure when you put new nozzles in???
You don't need to if it ran kinda alright before, but it's a good idea to.  They're usually worn out of spec by the time they need to be cleaned.
Mallinman
03-30-2017, 02:06 PM #6
I just wanted to change my nozzles but was worried about not having a pressure tester. Il get em changed then.
Borgwarner S200
Mallinman
Borgwarner S200
mrfajita
03-31-2017, 08:48 PM #7
Never pop tested mine, 617 ran way better after new nozzles. My 603 has had a few injector bodies swapped and idles like shit, I need to balance them
mrfajita
