STD Tuning Engine Om617a spin on oil filter
Evenglass
03-30-2017, 09:57 PM #1
I'm developing a spin on oil filter do to clearance issues. What should I do with the central tube that conects to the housing lid, I understand an air bleed.  It or leave it open?
Evenglass
OM616
10mm MW
572
03-31-2017, 05:00 PM #2
(03-30-2017, 09:57 PM)Evenglass I'm developing a spin on oil filter do to clearance issues. What should I do with the central tube that conects to the housing lid, I understand an air bleed.  It or leave it open?
Are you using the OEM base that attaches to the block? If so, you will need to plug the passageway that the tube plugs into. If I recall correctly (it has been a few years sense I did mine) I made a plug with an o-ring that I slid in (horizontally) somewhere behind the cover plate. A If you leave it open, oil will by pass the filter and go back through that passage to the crankcase making the oil pressure SUPER low if non existent.
OM616
NZScott
HX30W 73/44mm
398
03-31-2017, 06:31 PM #3
The system is designed so the top half of the oil filter is a bypass section, where a part of the oil flow goes through a tiny hole in the tube and returns to the crankcase. I think there might be a check valve in the system to stop air getting in and draining the entire filter housing out. (at least that's my theory going by my car and its oil pressure building delay with my turbo oil supply)
Silly question but why not use the OEM filter housing and relocate it? It's something that certainly helps the life of these engines.
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
Evenglass
03-31-2017, 10:41 PM #4
(03-31-2017, 06:31 PM)NZScott The system is designed so the top half of the oil filter is a bypass section, where a part of the oil flow goes through a tiny hole in the tube and returns to the crankcase. I think there might be a check valve in the system to stop air getting in and draining the entire filter housing out. (at least that's my theory going by my car and its oil pressure building delay with my turbo oil supply)
I literally have no room in my engine compartment. And not much room anywhere else for that matter.
Evenglass
Evenglass
03-31-2017, 10:44 PM #5
(03-31-2017, 05:00 PM)OM616
Yes, I am using the base. The info I needed. How did yours turn out? Any pictures ?
Evenglass
NZScott
HX30W 73/44mm
398
03-31-2017, 11:57 PM #6
(03-31-2017, 10:41 PM)Evenglass I literally have no room in my engine compartment. And not much room anywhere else for that matter.
Fair enough
1981 240D 498,000
1975 HJ45 ???,000
NZScott
Fair enough
1981 240D 498,000
1975 HJ45 ???,000
04-01-2017, 11:36 AM #7
I have a relocated oil filter, I bought an adapter from 300D50 many moons ago and just got a spin on base from napa
zeeman
04-01-2017, 02:05 PM #8
(04-01-2017, 11:36 AM)MFSuper90 I have a relocated oil filter, I bought an adapter from 300D50 many moons ago and just got a spin on base from napa
Someone on here was making some aluminum plates for relocating the original oil filter housing. Maybe you can find the source. Very important to retain the function of the original oil filter housing.
Zeeman
zeeman
Zeeman
OM616
10mm MW
572
04-01-2017, 07:24 PM #9
(03-31-2017, 10:44 PM)Evenglass Yes, I am using the base. The info I needed. How did yours turn out? Any pictures ?
 616 turbo in a 201 chassis
OM616
Evenglass
04-02-2017, 05:51 AM #10
(04-01-2017, 07:24 PM)OM616
Perfect.
Evenglass
Perfect.
Evenglass
04-02-2017, 05:55 AM #11
(04-01-2017, 02:05 PM)zeeman
Zeeman
Relocation is not an option. There's nothing special about the Mercedes drop in cartridge. The only piece I'll be replacing is the cartridge with a spin on element. I'll just have to make sure flow is at least  equal.
Evenglass
Zeeman
04-03-2017, 01:32 PM #12
So uh, should I make a run of relocation plates?
Evenglass
04-04-2017, 05:54 AM #13
(04-03-2017, 01:32 PM)Simpler=Better So uh, should I make a run of relocation plates?
This sells a nice on for cheap. I just don't have anywhere good relocate to.
http://www.mercedesdiesel4x4.com/mobile/...de=A-MB111
Evenglass
04-04-2017, 10:22 AM #14
Doomsday Diesel has them cheaper ($60):
http://doomsdaydiesel.net/PRODUCTS.html
Saves me from another side project Tongue
Evenglass
04-15-2017, 10:18 AM #15
<a href="http://s508.photobucket.com/user/evenglass1/media/20170412_173630_zpszdulfchk.jpg.html" target="_blank"><img src="http://i508.photobucket.com/albums/s324/evenglass1/20170412_173630_zpszdulfchk.jpg" border="0" alt=" photo 20170412_173630_zpszdulfchk.jpg"/></a>
<a href="http://s508.photobucket.com/user/evenglass1/media/20170412_173721_zpsvdejeszv.jpg.html" target="_blank"><img src="http://i508.photobucket.com/albums/s324/evenglass1/20170412_173721_zpsvdejeszv.jpg" border="0" alt=" photo 20170412_173721_zpsvdejeszv.jpg"/></a>
<a href="http://s508.photobucket.com/user/evenglass1/media/20170412_173706_zps5stfbbfr.jpg.html" target="_blank"><img src="http://i508.photobucket.com/albums/s324/evenglass1/20170412_173706_zps5stfbbfr.jpg" border="0" alt=" photo 20170412_173706_zps5stfbbfr.jpg"/></a>
My solution. It retains all the functionality of the factory unit but allows for alot of aftermarket options such as; 90* adapters, bypass oil systems, turbo feeds and sending units.
Evenglass
Evenglass
04-15-2017, 10:23 AM #16
Evenglass
Evenglass
04-15-2017, 10:24 AM #17
[Image: 20170412_173706_zps5stfbbfr.jpg]
Evenglass
Evenglass
04-15-2017, 10:26 AM #18
[Image: 20170412_173721_zpsvdejeszv.jpg]
Evenglass
Evenglass
04-15-2017, 10:28 AM #19
[Image: 20170412_173630_zpszdulfchk.jpg]
Evenglass
04-17-2017, 12:43 PM #20
It's purdy!
Get some glove tips over the onjectors before something gets in them!
It's purdy!
04-17-2017, 03:30 PM #21
Just a suggestion for the plate.... make sure you use either steel or aviation grade aluminum and make sure it's thick enough. I have a few plates and I got some from Walt years ago, and thicker seems a safer bet.
Evenglass
04-17-2017, 10:10 PM #22
(04-17-2017, 12:43 PM)Simpler=Better It's purdy!
Will do!
Evenglass
Will do!
Evenglass
04-17-2017, 10:11 PM #23
(04-17-2017, 03:30 PM)Greazzer Just a suggestion for the plate.... make sure you use either steel or aviation grade aluminum and make sure it's thick enough.  I have a few plates and I got some from Walt years ago, and thicker seems a safer bet.
What plate?
Evenglass
What plate?
04-18-2017, 10:25 AM #24
The adaptor plate which goes against the block so you can relocate the oil filter housing, either stock or newer style.
starynovy
04-18-2017, 02:02 PM #25
So when you change oil you loosen that and 1 liter of black shit floods whole engine?
starynovy
04-18-2017, 02:45 PM #26
(04-18-2017, 02:02 PM)starynovy So when you change oil you loosen that and 1 liter of black shit floods whole engine?
Poke a hole in the top and it will drain into the block.
But yes, I make a huge mess on my 4.0L Jeep very oil change.
OM616
10mm MW
572
04-18-2017, 02:46 PM #27
Not if you know what you are doing lol.. There are some tricks to keep from making a mess..
OM616
Evenglass
04-19-2017, 04:29 PM #28
No. The oil drains back the height of the standpipe inside the housing just like factory.
Evenglass
Evenglass
04-19-2017, 04:30 PM #29
(04-18-2017, 10:25 AM)Greazzer The adaptor plate which goes against the block so you can relocate the oil filter housing, either stock or newer style.
This is not for relocation.
Evenglass
