STD Tuning Engine OM617,7.5 m-pump electric fuel pump
scrubs
08-08-2017, 11:28 AM #1
Hi, looking for recomendations for an electric fuel pump
Thanks
scrubs
Thanks
R-3350
Dreaming of compounds
182
08-08-2017, 11:02 PM #2
depends on your budget if you are willing to spend a bit fuel labs makes some really nice pumps. they have a set up that uses a brushless dc motor with a built in on demand regulator controller that works with their fuel pressure regulator brick. if you are looking at a bit less there are a few good carter or airtex pumps that should flow enough still need a external fpr though to replace the stock banjo regulator. i have heard that the holley black pumps work but im not sure if they put out enough pressure to feed the pump well. basically anything that puts out more than 15psi and ~200LPH or higher (more might require up-sizing the feed and return from the tank though.
R-3350
