STD Tuning Engine DSL1 with 7,5/8mm element and manual box
EvoPeter
08-28-2017, 02:32 PM #1
Are there any one more then me out there running that setup?
This post was last modified: 08-28-2017, 02:33 PM by EvoPeter.
EvoPeter
firen456
08-29-2017, 12:53 AM #2
Yes, me... 8mm pump, 716 gearbox with SMF, HE351
This post was last modified: 08-29-2017, 12:54 AM by firen456.
firen456
EvoPeter
08-29-2017, 01:33 AM #3
(08-29-2017, 12:53 AM)firen456 Yes, me... 8mm pump, 716 gearbox with SMF, HE351
You have any problems with jerking between 1000-2300rpm?
EvoPeter
firen456
08-29-2017, 01:45 AM #4
Yes, minimized it by adding a additional spring to the rack. Only have jerking in part-load condition. The coil has too lees spring tension at low IQs. Also using the new pump map helped to get rid of the jerking issue. There are still some oscillations left. First I will try to add a harder spring. If this will work I will set the brackets towards more fuel = more tension on same IQ.
Have you problems with nailing? The 8mil elements nailed horribly in part load. I've got a soluton about this... What about nailing on the 7.5mm elements?
firen456
EvoPeter
08-29-2017, 03:21 AM #5
(08-29-2017, 01:45 AM)firen456 Yes, minimized it by adding a additional spring to the rack. Only have jerking in part-load condition. The coil has too lees spring tension at low IQs. Also using the new pump map helped to get rid of the jerking issue. There are still some oscillations left. First I will try to add a harder spring. If this will work I will set the brackets towards more fuel = more tension on same IQ.
I had nailing at midd rpm with 8mm mechpump and WOT. Not with 7,5mm mechpump and not with 7,5mm EDC. Use same drivegear with alittle more advance in higher rpm (grinded stopps) on all pumps.
Okay, so you are the guy that Baldur refers to. So i might need to send my pump to Dieselmeken again to put the spring in after i find one? I opened another EDC and i had to remove the rack to get the spring out.
EvoPeter
firen456
08-29-2017, 03:44 AM #6
Yes, I am... First try to get it right by adding a spring on the rack befor the first bracket so there is more tension on the rack. In my case this made it a lot better. You can try it by your self. Of course you have to change then base pw settings, too.
firen456
firen456
08-29-2017, 03:46 AM #7
for the additional spring you don't have to remove the rack.
firen456
EvoPeter
08-29-2017, 04:32 AM #8
Maybe you have a pic?
Yeah i would need to change the base pw settings after the spring.
EvoPeter
firen456
08-29-2017, 05:19 AM #9
No, I'm 400km away from home :Sad  Pm me, I will take you a picture this weekend.
firen456
Mr.Emo
Nissan Patrol -> 606 conversion.
69
08-29-2017, 06:40 AM #10
Please post pictures here. This fix might be suitable for others aswell. I am also planning on going 7.5 meken and baldur ecu.
Mr.Emo
EvoPeter
08-29-2017, 06:42 AM #11
Otherwise from the oscillations its a great pice of ECU.
EDIT: With 6mm pump i had no problems with jerking/oscillations. It seems that with 7,5/8mm the rack spring on low load is to weak and element is to effective.
This post was last modified: 08-29-2017, 06:44 AM by EvoPeter.
EvoPeter
maxypriest
08-29-2017, 11:54 AM #12
I'm not exactly sure what has done it however I have made a number for changes to my car and the jerk has completely gone after about 1200 rpm.
maxypriest
EvoPeter
08-29-2017, 04:36 PM #13
(08-29-2017, 11:54 AM)maxypriest I'm not exactly sure what has done it however I have made a number for changes to my car and the jerk has completely gone after about 1200 rpm.
Would you mind share your map so i could test it in my car?
EvoPeter
maxypriest
08-30-2017, 03:53 AM #14
Well that’s the catch, I’m not using an EDC, it’s a mech pump that had the bonanza/Jerk.
I have not touched the engine/transmission.
I changed the rear flex disc to a bigger one, a stronger prop, longer ratio 210mm diff, poly bushed diff to subframe mounts, uprated trans mount different wheels and tyres. Something I did there eliminated the jerk, (it’s not reduced its eliminated) and the car is now infinitely nicer to drive.
maxypriest
EvoPeter
08-30-2017, 04:46 AM #15
(08-30-2017, 03:53 AM)maxypriest Well that’s the catch, I’m not using an EDC, it’s a mech pump that had the bonanza/Jerk.
Ohh ok. Never had that problem with 4 different pump. But this EDC one have oscillation on low racktravel. You can feel it and see it in the computer.
EvoPeter
maxypriest
08-30-2017, 05:04 AM #16
interesting! 4 mech pumps without jerk? Nice.
DPUK is working on something that might help. Very early days.
maxypriest
maxypriest
08-30-2017, 05:29 AM #17
Ahhh are they all 5cyl engines?
maxypriest
EvoPeter
08-30-2017, 06:53 AM #18
(08-30-2017, 05:04 AM)maxypriest interesting! 4 mech pumps without jerk? Nice.
Sorry, 3 mechpumps. Old 7mm, Dieselmeken 7,5mm and Pekka Herlevi 8mm with same om605 engine.
EvoPeter
08-30-2017, 10:28 AM #19
Everybody who has low ratio diff s that i know with maxed out mech pumps have some jerk ... DMF 's and other fancy harmonics absorbing devices help... but the thing is i start to belive in witches...
Adding tension to the rack spring and diminushing the tq control control help a lot... but in some pumps does not solve the matter at all.
I have a pretty much idea of why it does in mech pumps but the idea need to be tested and it takes time....
Regards
Regards
baldur
Fast
506
08-30-2017, 12:05 PM #20
(08-30-2017, 10:28 AM)barrote Everybody who has low ratio diff s that i know with maxed out mech pumps have some jerk ... DMF 's and other fancy harmonics absorbing devices help... but the thing is i start to belive in witches...
Regards
The problem is in part caused by the orientation of the rack inducing a feedback between vehicle acceleration and rack position. The rack is mounted longitudally and so sudden acceleration of the car pushes the rack back a bit reducing fuelling, and sudden deceleration pushes the rack forward. I noticed this when I had a mech pump in my car, if I was in neutral gear and braking hard the engine would hang at high RPM until I was done braking, then it would fall back to idle.
Baldur Gislason
baldur
Regards
Baldur Gislason
08-30-2017, 12:51 PM #21
Sorry baldur ,
i was not talking about that ... its nothing related to that ... jerking people complain and i too have is part load driving and not cause of what u refer above, wich i do not refute.
Looks like people complain of dsl1 powered pumps too, and why is the driver induced oscilations... well i have no answear to that ...
For the mech pumps i have , and when i have complete control over it i'll post my conclusions , and solutions.
For the moment i can recomend to increase rack spring tension to 2 as much , and for those u can and know how to do it reduce tq control cut out to min.
I do hope toguether we can fight this problem with success.
Sorry baldur ,
baldur
Fast
506
08-30-2017, 03:08 PM #22
(08-30-2017, 12:51 PM)barrote Sorry baldur ,
The same mechanism also plays in the jerking. When the car accelerates and decelerates repeatively those motions feed into the rack.
Baldur Gislason
baldur
Baldur Gislason
NZScott
HX30W 73/44mm
398
08-31-2017, 12:42 AM #23
And here I am thinking it was my right foot going back and forth with the car going back and forth...
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
baldur
Fast
506
08-31-2017, 12:57 AM #24
(08-31-2017, 12:42 AM)NZScott And here I am thinking it was my right foot going back and forth with the car going back and forth...
That is also a contributing factor when the amplitude gets severe.
Baldur Gislason
baldur
Baldur Gislason
firen456
08-31-2017, 01:34 AM #25
Even with the pedal floored (no oscillation in the drivers wish) the engine is oscillating. In my opinion the rack can't get into home-position that fast it should. The coil wants to move the rack towards less fuel, but it gets stuck a little bit. After a little time the rack is moves towards less fuel, too and goes below the target point. The PID-loop governs the rack and coil towards the targetpoint and overshoots a little bit. Now the PID-loop gives less pw and the coil has less tension. And everything starts from new...
Adding a additional spring to make the rack-tension higher did major success. I will add a harder one and see what happens...
firen456
bruno_pinho
08-31-2017, 07:32 AM #26
I do not understand, edc pump not jerking, for me this is remap problem..
bruno_pinho
EvoPeter
09-01-2017, 06:13 PM #27
Installed a second spring. Its now better. The car is drivabel.
Made a spring that would be a good replacement for the main spring. But then i need to send the pump to meken again.
EvoPeter
firen456
09-02-2017, 08:12 AM #28
Have you measured your spring? I didn't have time so far to make a picture... I'm very busy this weekend Sad
firen456
EvoPeter
09-02-2017, 12:53 PM #29
(09-02-2017, 08:12 AM)firen456 Have you measured your spring? I didn't have time so far to make a picture... I'm very busy this weekend Sad
No and it was difficult to install. Im going to call meken on monday to discuss a heavier main spring and maybe send the pump to him again to install one over the winter.
Was on the track whole day today and the car have great power all up to 6600rpm were my limit is at the moment. The setup i have this summer with this EDC pump is the best so far. For the first time im very satisfied with the register and power.
This post was last modified: 09-02-2017, 12:55 PM by EvoPeter.
EvoPeter
EvoPeter
09-04-2017, 07:26 AM #30
So... Did just get off the phone with Göran "Dieselmeken". I will send him my pump and spring ive made and he will do some investigation and tests. We think we have a solution about the oscillation.
I said to Göran that this thred exist and if he wants to write about his ideas or solution he is free to do so here.
I will report back about my pump when i get it back.
EvoPeter
firen456
09-04-2017, 07:50 AM #31
Ok, wonderful  Smile I wonder what causes this issue... Maybe he will find out what's going on there. The EDC-pumps seem to be weird in some cases... Where a 8mil element is running fine in a mech pump, the same element is nailing like hell in a EDC-pump for example. I'm interested if this oscillation-issue can be caused in a pump-bench, too... Whithout the engine running, there is no oscillation, only with the engine running it appears. And only at a certain enginespeed. The same thing about the nailing of the 8mil pump. But there is a solution to minimize it.
firen456
EvoPeter
09-04-2017, 08:40 AM #32
(09-04-2017, 07:50 AM)firen456 Ok, wonderful  Smile I wonder what causes this issue... Maybe he will find out what's going on there. The EDC-pumps seem to be weird in some cases... Where a 8mil element is running fine in a mech pump, the same element is nailing like hell in a EDC-pump for example. I'm interested if this oscillation-issue can be caused in a pump-bench, too... Whithout the engine running, there is no oscillation, only with the engine running it appears. And only at a certain enginespeed. The same thing about the nailing of the 8mil pump. But there is a solution to minimize it.
One thing i think is doing it is the timing advance. More advance less rack and fuel. If timing is changed to quick then the pump tries to compensate and then it starts. Thats why every thing is okay when engine is off and no load to engine.
The original spring is to weak at a racktravel of 800-1100 in Baldur ECU and i guess that the solenoid have problem to compensate and start to oscillate. A harder spring seems to compensate this according to both yours and my live tests.
I did put in a harder spring and i have almost no oscillation now compare to before the spring.
About the nailing for you, try to retard the timing?
EvoPeter
EvoPeter
09-07-2017, 04:06 AM #33
Done some more investigation and talk with Dieselmeken. We might be on a easy solution with racktravel and idle settings with Baldur ECU. So its possible in the future to get same racktravel (21mm) with EDC pump as with Mech pump thanks to the tip of firen456.
EvoPeter
JoeB
09-09-2017, 11:13 PM #34
When you have resolved the issue, please let us know.
I have a spare EDC pump here on my second 606, which I would like to send to Goran for an upgrade, but it's a completely pointless exercise for me to do so if there is no proven solution available.
My other pump is mech603, and reconditioned to new locally but tuned with .964 elements - it is obviously quite good for it's intended function. Stock 606 turbo, so no need to go bezerk on it.
The spare engine I want to go DSL1 for my own reasons. If 7+mm elements cause the oscillation then I'll need some documented facts to support doing it.
JoeB
EvoPeter
09-11-2017, 02:03 AM #35
(09-09-2017, 11:13 PM)JoeB When you have resolved the issue, please let us know.
I will write here when we have a solution.
EvoPeter
BobbyBreeze
11-02-2017, 04:27 PM #36
Thought this could be useful for this thread. DieselpumpUK anti jerk setup. Could be worthwhile trying on the EDC pumps with larger elements.
https://youtu.be/KucwBFD3nr4
BobbyBreeze
Mr.Emo
69
11-03-2017, 12:34 AM #37
(11-02-2017, 04:27 PM)BobbyBreeze Thought this could be useful for this thread. DieselpumpUK anti jerk setup. Could be worthwhile trying on the EDC pumps with larger elements.
That is for mechanical pumps only?
Mr.Emo
BobbyBreeze
11-04-2017, 05:36 PM #38
He states in the video it will fit EDC pumps too.
BobbyBreeze
Mr.Emo
69
11-06-2017, 06:38 AM #39
He has to stop making shiny things. Will eventually go broke!
Mr.Emo
firen456
11-21-2017, 04:54 PM #40
any news?
firen456
any news?
maxypriest
11-22-2017, 08:42 AM #41
OK – I have just been on the phone to DPUK and they have fitted an Anti Jerk kit to a costumer’s car that had it so bad it would even do it on the rolling road.
The kit has completely illuminated the jerk/bonanza. For £300 the kit is an absolute steal, the jerk thing can completely ruin any STD project.
(PS – for some reason 5 cyl cars/pumps are not prone to jerking – dunno why but that’s just how it is.)
maxypriest
firen456
11-22-2017, 11:39 AM #42
but it is still not prooved wit an EDC-pump und the DSL1?
firen456
maxypriest
11-22-2017, 11:43 AM #43
Nope - not yet, but I'm willing to bet the issue is the basically the same.
Someone needs to try it out.
maxypriest
Petar
7.5mm M pump
459
11-24-2017, 04:01 PM #44
On old diesel engines that would jerk(rpms go up and down mostly at idle and low rpm) we used 90 weight gear oil instead of regular motor oil in the pump governor. The thick oil would dampen worn out governors and stop the hunting effect. Of course this is impossible in engines that use pumps lubricated from the engine oil circuit.
The DPUK solution is very similar and quite genius.
Petar
NZScott
HX30W 73/44mm
398
11-25-2017, 12:00 AM #45
My 5 cylinder jerks (jerked...) quite a bit. Maybe it was due to the gearing setup (3.46 diff)
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
maxypriest
11-27-2017, 07:54 AM #46
(11-24-2017, 04:01 PM)Petar On old diesel engines that would jerk(rpms go up and down mostly at idle and low rpm) we used 90 weight gear oil instead of regular motor oil in the pump governor. The thick oil would dampen worn out governors and stop the hunting effect. Of course this is impossible in engines that use pumps lubricated from the engine oil circuit.
Petar - Ha! That's superb info,  I suspected this would be the case - some cars with the jerk get worse as the engine heats up an I was thinking about somehow sealing the pump and running it in thicker oil.
Mine still hunts at idle - I'm looking fwd to see what difference the kit will make in this regard.
maxypriest
EvoPeter
12-04-2017, 11:20 AM #47
In begining of february i will come with updates. Spoke to Dieselmeken some weeks ago.
I have had some jerk with 5-cyl and 3 diff. Mech. pumps.
This post was last modified: 12-04-2017, 11:22 AM by EvoPeter.
EvoPeter
supracrazy
09-09-2018, 04:56 PM #48
Any update on this?
supracrazy
Any update on this?
 12 Guest(s)
 12 Guest(s)
