STD Tuning Engine om617 turbo oil feed question
Metzone
11-20-2017, 11:22 AM #1
I am reassembling my om617. The factory oil feed line for the turbo will not work. I would like to hear your suggestions. I want to replace it with a braided line. I read somewhere that the feed needs a restriction?  Any input will be appreciated.I would like a banjo to -4 an fitting. Any links to parts would be a help.
Thanks
Metzone
Thanks
R-3350
Dreaming of compounds
182
11-20-2017, 07:54 PM #2
im running a an4 line from a banjo off the original feed port in the oil housing. as for the restrictor it depends on the turbo look up the specs on what you are using and see what the manufacturer recommends for oil pressure.
R-3350
