STD Tuning Drivetrain Clutch options om605
Antonio
01-17-2018, 10:55 AM #1
so om605 around 250hp with 717.432 gearbox, what clutch to use? stock one i think is to weak? havent tried it yet... any sugestions?
Antonio
juggs
01-18-2018, 01:09 PM #2
I use this set up , also sub 250hp 2871r turbo with remap & EDC 6mm pump OM605.
I use stock dual mass flywheel, when clutch started slipping I got brand new genuine clutch, use stock pressure plate with a re manufactured friction plate using heavy duty material (same as earth mover etc).
Works fine for me so far, bit more noise than stock but retains OEM feel at the pedal
juggs
Antonio
01-19-2018, 03:20 AM #3
i am using solid flywheel and stock cluch but it is worn, havent really tried the limit of it but... you got oem friction disc redid with HC material?
Antonio
