STD Tuning Engine Box Section Exhaust Manifold OM606
engineengineer
03-21-2018, 04:27 PM #1
Hi all, wondered whether anyone had ever experimented with an exhaust manifold made of welded plate steel? I can buy a manifold flange for around £50 Euro. Also is the manifold bolt pattern different on turbo/non turbo 606?
Thanks
This post was last modified: 03-21-2018, 04:31 PM by engineengineer.
engineengineer
Thanks
AlanMcR
mind - blown
400
03-21-2018, 07:12 PM #2
Seems like that would flow quite differently than a tube manifold. I doubt it would be better.
I believe that the exhaust manifold mounting bolts for the NA and turbo are the same.
AlanMcR
NZScott
HX30W 73/44mm
398
03-21-2018, 09:34 PM #3
You're going to get terrible efficiency with a big open space for the exhaust gases to slow and expand into. But I cringe at rear mounted turbos.
I remember reading a forum about a guy who made a turbo manifold out of actual box section for a Toyota H diesel. So that's been done.
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
