STD Tuning Engine stand alone VNT controllers- who has experience with this?
MTUPower
287
04-05-2018, 06:34 AM #1
https://store.suprocktech.com/products/turbo-commander
anyone used this for a 617-95X?
MTUPower
baldur
Fast
506
04-05-2018, 07:33 AM #2
Wow that's a lot of money!
Baldur Gislason
baldur
Baldur Gislason
atypicalguy
04-05-2018, 05:52 PM #3
(04-05-2018, 07:33 AM)baldur Wow that's a lot of money!
I don't know what your controllers go for Baldur but this one is about $750:
https://steeds.tech
It works for holsets and many other VNT turbos also.
FYI. I have never used any of them, but would consider doing so on next build if compounds are not doing well enough.
atypicalguy
https://steeds.tech
baldur
Fast
506
04-06-2018, 05:00 AM #4
(04-05-2018, 05:52 PM)atypicalguy
https://steeds.tech
Mine go for 650. That does not include any wiring but it does include software that is far more refined than either of the two examples in this thread, and it controls everything related to the engine and not just the turbocharger.
Baldur Gislason
baldur
https://steeds.tech
Baldur Gislason
MTUPower
287
04-06-2018, 05:42 AM #5
If you have a 617-95X then there is nothing other than the turbo to control. Do you have a system which is plug and play with that in mind?
MTUPower
baldur
Fast
506
04-06-2018, 01:46 PM #6
(04-06-2018, 05:42 AM)MTUPower If you have a 617-95X then there is nothing other than the turbo to control.  Do you have a system which is plug and play with that in mind?
Not plug and play, no. I mean I have more than one product that can do it but none of them have boost control as a primary function, they're designed to do other things but can also do boost control.
Baldur Gislason
baldur
Baldur Gislason
AlanMcR
mind - blown
400
04-06-2018, 04:38 PM #7
Boost control for any kind of modern diesel really should be based on a computed air demand. Running the intake pressure up to some arbitrary value just adds to exhaust back pressure at times when the engine isn't at full output. And that is basically 99% of the time.
Even the relatively simple ECU on the OM606 does this with the computer controlled wastegate. It runs the pressure up high enough to meet the fueling and no more. The wastegate is constantly moving back and forth in order to manage boost and provide back pressure for EGR performance.
AlanMcR
baldur
Fast
506
04-06-2018, 06:06 PM #8
(04-06-2018, 04:38 PM)AlanMcR Boost control for any kind of modern diesel really should be based on a computed air demand.  Running the intake pressure up to some arbitrary value just adds to exhaust back pressure at times when the engine isn't at full output.  And that is basically 99% of the time.
Yes, exactly.
Baldur Gislason
baldur
Yes, exactly.
Baldur Gislason
MTUPower
287
04-06-2018, 06:29 PM #9
lol- Is the 617-95X a "modern diesel" ? Mine doesn't have a EGR, nor does it have a computer. Do I want it to run high boost all the time? No. Do I want boost at low rpm? Absolutely.
Edit- no idea why my sig says "Holset". Anyone know how to change that? thx
This post was last modified: 04-06-2018, 06:34 PM by MTUPower.
MTUPower
AlanMcR
mind - blown
400
04-06-2018, 10:09 PM #10
Doesn't really matter if it is modern or not. The vanes will get closed down all the way even if there is no need for boost.
AlanMcR
baldur
Fast
506
04-07-2018, 06:45 AM #11
(04-06-2018, 10:09 PM)AlanMcR Doesn't really matter if it is modern or not.  The vanes will get closed down all the way even if there is no need for boost.
Yeah, but that just means to control the VNT properly a throttle position sensor must be fitted as well as engine speed sensor so the pressure target can be varied depending on throttle position and engine speed.
Baldur Gislason
baldur
Baldur Gislason
MTUPower
287
04-07-2018, 08:18 AM #12
...and we get back to the first post: can you make this for a 617-95X?
MTUPower
R-3350
Dreaming of compounds
182
04-08-2018, 02:41 AM #13
what are your power goals? you said you want something quick spooling for down low torque and drivability but how much power do you want? if all your aiming for is 3-400 thats doable with a nice single that will light quite quickly. for example for the price of that vnt controller and a good HE351 you could get a borg warner EFR 7163 which would have much the same response while also being a more responsive turbo with more features as well.
R-3350
starynovy
04-08-2018, 02:39 PM #14
There is a guy.. dmn? He made it free on arduino base. Uses pre-control and PID regulation, inputs are engine speed, pressure and throttle demand so pretty much OE like. But not everyone is handy enough with electronics to use it.
starynovy
Petar
7.5mm M pump
459
04-09-2018, 01:13 PM #15
This one:
http://dmn.kuulalaakeri.org/vnt-lda/
It is open source.
Shouldn't be too complicated to make a controller with some basic electrical knowledge, and for far less money, I'd say 50-100 dollars max for the entire project.
Petar
This one:
It is open source.
MTUPower
287
04-09-2018, 07:33 PM #16
(04-08-2018, 02:41 AM)R-3350 what are your power goals? you said you want something quick spooling for down low torque and drivability but how much power do you want? if all your aiming for is 3-400 thats doable with a nice single that will light quite quickly. for example for the price of that vnt controller and a good HE351 you could get a borg warner EFR 7163 which would have much the same response while also being a more responsive turbo with more features as well.
300-400 HP out of a 617-95X is quite a large amount.  The EFR 7163 doesn't come with a T3 but that can be overcome.
I'd like to have more than the low 200's- but not more than 300.  I don't want to be buying and installing new transmissions on a regular basis...  plus I don't have a LSD.
MTUPower
R-3350
182
04-10-2018, 03:57 AM #17
a Holset HX30 will support around 250 at the max. the HE221W im running now will do about the same and it lights well below the torque converter stall. if you are aiming for less than 300 then theres no point really in going vnt. the controllers you were looking at are mostly for larger modern VNT turbos like a HE351 but that is good for more like 350-400HP. below 300 there are plenty of readily available options for much cheaper than a controller and turbo that will light low enough to make for a fun drive.
R-3350
MTUPower
287
04-10-2018, 06:22 PM #18
What do you all collectively think of a T25 .64A/R EFR-6258?
MTUPower
R-3350
182
04-10-2018, 10:18 PM #19
likely a bit more than you need the 6258 should supply at max about 320-330 worth of air. also you would need to plumb coolant to it for water cooling. since your power goals are small i would just go for a nice genuine holset HX30/HE221W or a garett GT2859 or similar.
R-3350
MTUPower
287
04-11-2018, 03:38 PM #20
R-3350 do you have any video's of you car driving? Any pics?
MTUPower
R-3350
182
04-11-2018, 10:27 PM #21
i got a few quick videos and i shot a quick walk-around earlier but they're too large to upload. if you wana PM me ill send them
R-3350
