STD Tuning Engine OM 606 Turbo Gasket to Manifold
zeeman
09-21-2018, 03:39 PM #1
Looking for part number for the triangle gasket between the turbo and exhaust manifold, for a 98-99 OM 606. Mercedes dealer has no listing for it. And I don't seem to find it anywhere?
zeeman
Alec300SD
09-21-2018, 11:56 PM #2
No gasket from the factory.
Iffy looking aftermarket gasket thay may fit???
https://www.ebay.com/itm/Turbo-Gasket-fo...1669244665
Edit:  The ELRING  EL715530 kit looks more promising
https://www.ebay.co.uk/itm/TURBOCHARGER-...#vi-ilComp
This post was last modified: 09-22-2018, 12:35 AM by Alec300SD.
Alec300SD
09-22-2018, 02:04 AM #3
Use exaust cement and direct fit without gasket.
It holds .
It holds .
zeeman
09-22-2018, 02:30 PM #4
(09-21-2018, 11:56 PM)Alec300SD No gasket from the factory.
Every used engine I use in my conversions has a gasket? I have never seen one without.
zeeman
50harleyrider
GTA2359VK
397
09-23-2018, 02:20 PM #5
no gasket there-none needed. Here's probably the most comprehensive turbno application website out there. Has part numbers for turbo components too:
http://www.turbomaster.info/eng/applicat...s+benz/3K/
50harleyrider
zeeman
09-24-2018, 10:59 AM #6
(09-23-2018, 02:20 PM)50harleyrider no gasket there-none needed. Here's probably the most comprehensive turbno application website out there. Has part numbers for turbo components too:
Thanks for the info, on my Jeep Cherokee conversions I have to use a 45 degree adapter to move the turbo away from the subframe and need to gasket both ends.
zeeman
