STD Tuning Drivetrain OM605 with cdi gearbox
Antonio
11-02-2018, 09:01 AM #1
i am trying to get a gearbox that would hold 300-350hp, om605 engine and i have a few questions
-can i use solid flywheel?
-270cdi gearbox can fit in 190 chasis without modification of body?
-how to connect speedometer to 190 cluster?
Cheers!
Antonio
Cheers!
Petar
7.5mm M pump
459
11-13-2018, 05:46 PM #2
You can use only the single mass flywheel from the sprinter conversion kit (Valeo 831013 I think). Stock single mass flywheel will not work input shaft is too short ,it won't fit into the pilot bearing.
I don't know if it will physically fit.
You need to convert the speedometer to electronic since there is no cable drive in the gearbox. The W126 speedometer is commonly used with some cutting to fit.
Petar
Antonio
11-29-2018, 11:47 AM #3
w126 has electronic speedometer? do you have any specific information?
Antonio
Petar
7.5mm M pump
459
12-03-2018, 05:57 PM #4
I've heard that all W126's had electronic speedometers. But I can't confirm it since I've never seen them myself, it's a relatively rare car over here.
https://www.youtube.com/watch?v=ffW6nGFR9X4
http://www.superturbodiesel.com/std/show...9#pid83779
This post was last modified: 12-03-2018, 05:59 PM by Petar.
Petar
Antonio
12-11-2018, 10:40 AM #5
oh, i get it. Curently i have no time to play with that project but do you know how much power can stock 2.5d (717.423) gearbox from 190d take? is there any gearbox from w201 or w124 chassis to fit and hold 300 hp?
This post was last modified: 12-11-2018, 10:50 AM by Antonio.
Antonio
Petar
7.5mm M pump
459
12-11-2018, 03:46 PM #6
As far as I know all Mercedes 5 speeds are quite weak. The 3rd gear breaks first. 717.460 from C250TD should be a bit stronger, maybe it could handle 300hp. You can swap the tail housing for one with a mechanical speedo drive from an older gearbox.
717.404 dog leg (first gear left and backwards) five speed from the 190E 2.3 - 16V is much stronger than Mercedes gearboxes, but it only has 1:1 5th gear . 717.450 is the same gearbox but with short input shaft for dual mass flywheel, it was fitted to the 300E - 24V
Petar
