STD Tuning Engine OM606.962 Valve Float @ raised boost?
erx
w202 om606
323
12-19-2018, 04:03 PM #8
(12-19-2018, 03:40 PM)jav1 So the 3.5 bar boost was with stiffer valve springs?  Yes- turbo is small but is used on 3.2 liter diesel so I'm hoping it will be OK with my 3 liter.  I know vanes are wide open and I have 3" exhaust so if there is a restriction- its the turbos exhaust section.
I doubt I have 4.5 bar EGP but who knows?  I installed Chinese 7 bar map that didn't last very long.  I have a 5 bar GM coming tomorrow.... we'll see what it is BUT- to be sure- your 4.5 bar was with the stiffer valve springs.. correct?
it made 3.5bar boost with stock springs after I put better exhaust. From which 3.2 engine your turbo came from? I don't know how many different versions of gt2056v's there are but I belive it's even smaller than om606 stock turbo. I use gt2359v which is a little bigger than stock om606 and it spools instantly.
This post was last modified: 12-19-2018, 04:04 PM by erx.
erx
Messages In This Thread
OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 01:23 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 12-19-2018, 01:50 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 02:13 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 03:00 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 03:12 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 03:22 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 03:40 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 04:03 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 04:18 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 04:36 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 09:18 PM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 01:08 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 08:13 AM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 08:28 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 08:40 AM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 10:40 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 11:03 AM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-20-2018, 03:20 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 05:49 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-22-2018, 12:47 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-23-2018, 09:54 PM
RE: OM606.962 Valve Float @ raised boost? - by Ecto - 03-14-2019, 10:35 AM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 02:43 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-14-2019, 01:17 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 02:51 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-15-2019, 12:14 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 03:45 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-15-2019, 07:02 PM
RE: OM606.962 Valve Float @ raised boost? - by X Double Dot - 01-13-2022, 03:30 PM
