STD Tuning Engine OM606.962 Valve Float @ raised boost?
jav1
12-20-2018, 11:03 AM #17
Yeah- there was quite a lot of talk about this and the way I read it (and I've now re-read it 3 times) was ....   Yes with the CDI engine, the intake spring was made weaker BUT the exhaust spring was left "the same"- except they changed the part number twice.
And by "the same" I believe that means it was the same spring as the original OM606.962  exhaust spring.
One guy did compare an old OM606.962 exhaust spring against a NEW 61105300220 on a bolt and found the new one compressed less than the old one BUT... the size of the spring, wire and all, was the same.  It was my understanding from that- that the "stiffness" of the new spring was just because it was NEW - not because it was really a higher rate spring?
This post was last modified: 12-20-2018, 11:05 AM by jav1.
jav1
Messages In This Thread
OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 01:23 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 12-19-2018, 01:50 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 02:13 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 03:00 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 03:12 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 03:22 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 03:40 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 04:03 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 04:18 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 04:36 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 09:18 PM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 01:08 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 08:13 AM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 08:28 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 08:40 AM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 10:40 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 11:03 AM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-20-2018, 03:20 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 05:49 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-22-2018, 12:47 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-23-2018, 09:54 PM
RE: OM606.962 Valve Float @ raised boost? - by Ecto - 03-14-2019, 10:35 AM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 02:43 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-14-2019, 01:17 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 02:51 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-15-2019, 12:14 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 03:45 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-15-2019, 07:02 PM
RE: OM606.962 Valve Float @ raised boost? - by X Double Dot - 01-13-2022, 03:30 PM
