STD Tuning Engine OM606.962 Valve Float @ raised boost?
erx
w202 om606
323
12-22-2018, 12:47 PM #20
(12-20-2018, 05:49 PM)jav1 Thats fantastic!  Did you test again after the new spring?
I didn't test it with new springs because I tested stock springs on spare engine. Only difference I noticed after spring swap is that engine is making a little louder noise on idle and it made a little more boost. Springs came from KMcams and they were about twice as stiff, I don't remember any numbers.
erx
Messages In This Thread
OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 01:23 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 12-19-2018, 01:50 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 02:13 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 03:00 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 03:12 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 03:22 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 03:40 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 04:03 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 04:18 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 04:36 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 09:18 PM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 01:08 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 08:13 AM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 08:28 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 08:40 AM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 10:40 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 11:03 AM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-20-2018, 03:20 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 05:49 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-22-2018, 12:47 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-23-2018, 09:54 PM
RE: OM606.962 Valve Float @ raised boost? - by Ecto - 03-14-2019, 10:35 AM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 02:43 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-14-2019, 01:17 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 02:51 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-15-2019, 12:14 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 03:45 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-15-2019, 07:02 PM
RE: OM606.962 Valve Float @ raised boost? - by X Double Dot - 01-13-2022, 03:30 PM
