STD Tuning Engine OM 606 head porting
OM 606 head porting
OM 606 head porting
zeeman
01-13-2019, 12:03 PM #1
Has anyone done any head porting on the OM 606 engine? Is there any benefits of doing any porting work?
zeeman
firen456
01-13-2019, 12:38 PM #2
Yes. Exhaust side is a very small restriction. Intake is almost perfect. I also fitted bigger valves and machined the seats to fit the bigger valves. Torue ove the whole rpm-band increased signifincantly.
firen456
zeeman
01-13-2019, 09:00 PM #3
(01-13-2019, 12:38 PM)firen456 Yes. Exhaust side is a very small restriction. Intake is almost perfect. I also fitted bigger valves and machined the seats to fit the bigger valves. Torue ove the whole rpm-band increased signifincantly.
Did you go with bigger valves on the exhaust as well as the intake? What did you use for valves, seats and guides?
Zeeman
zeeman
Zeeman
firen456
01-14-2019, 01:40 AM #4
Went both sides with CDI valves. I Used the 7mm cdi valve guides. Seats in the head were cut bigger and seats on the valves were regrinded. The valves are 1,5mm shorter if i remeber it right... Uses Lashcaps to compensate that.
firen456
zeeman
01-14-2019, 02:14 AM #5
(01-14-2019, 01:40 AM)firen456 Went both sides with CDI valves. I Used the 7mm cdi valve guides. Seats in the head were cut bigger and seats on the valves were regrinded. The valves are 1,5mm shorter if i remeber it right... Uses Lashcaps to compensate that.
So you used the original seats and cut them bigger? And used the inline 6 cylinder CDI valves? Were did you get the lash caps from?
Thanks Zeeman
zeeman
Thanks Zeeman
firen456
01-14-2019, 07:41 AM #6
exactly... Used 1mm schrick lash caps. 6mm in diameter.
firen456
JoeB
01-14-2019, 11:09 AM #7
Did you need to fly-cut pistons for valve clearance? Or is the bottom end standard om606?
JoeB
zeeman
01-14-2019, 12:03 PM #8
(01-14-2019, 07:41 AM)firen456 exactly... Used 1mm schrick lash caps. 6mm in diameter.
I see were F-tune also makes different thickness lifter shims also.
Thanks for all the info.    Zeeman
zeeman
firen456
01-14-2019, 01:21 PM #9
Yes, had to mill the gaps in the pistons. But not that much. Only like 0.5-1mm. I did that free hand with a real mans dremel. You have to work very carefully. But it would be better to get the pistons out the engine and do the job on a mill.
firen456
zeeman
01-14-2019, 10:33 PM #10
How thin do the seats get? It looks like the intake seat is already thin, the exhaust not so much.
zeeman
zeeman
01-14-2019, 10:36 PM #11
What RPM do you feel the torque improved the most? Just wondering if a offroad vehicle would benefit that much vs a street machine.
zeeman
firen456
01-15-2019, 06:44 AM #12
I don't have a dyno graph before/after. You have to try this by your own.
firen456
 3 Guest(s)
 3 Guest(s)
