STD Tuning Engine Stronger OM606 headbolts?
AlanMcR
mind - blown
400
04-05-2020, 09:46 PM #1
Looks like I've stretched out at least one head bolt again.  Believe the last set was "VictorReinz".  I haven't actually pulled the  head off, but the last time, two bolts (between cylinders 1 & 2) were loose to the touch and had been stretched an extra 2-3mm in the threaded portion. The head was flat, in fact it was quite driveable (no leakage) as long as one didn't drive it hard.
This is in the G, which is a tad too heavy for the engine.  On long loaded hill climbs it is continuously putting out max power.
Is there a stronger alternative?  Other diagnoses?  Maybe ease up on the throttle?
AlanMcR
baldur
Fast
506
04-06-2020, 07:37 AM #2
If you have your head and block separated you can make some measurements and send an inquiry to ARP to assemble a set that will work. I did this for my OM602.
I have attached the measurement sheet that I made for the 602.
Get in touch with ARP at https://arp-bolts.com/p/contact.php
.xls
Head Main Calc Sheets Al.xls
Baldur Gislason
baldur
.xls
Baldur Gislason
zeeman
04-06-2020, 12:33 PM #3
(04-06-2020, 07:37 AM)baldur If you have your head and block separated you can make some measurements and send an inquiry to ARP to assemble a set that will work. I did this for my OM602.
You need to spend the money and buy genuine Mercedes head bolts and torque them using the correct factory method. What kind of EGT temps are you pulling ?
zeeman
AlanMcR
mind - blown
400
04-06-2020, 01:42 PM #4
Thanks, I'll look into that.  Their site doesn't seem very well oriented towards mixing and matching parts for vehicles that they don't make kits for.
As far as buying genuine MB bolts, I'd need to be convinced that they were any better.  MB has not always been the best source.  Unsure of the EGT, but the first problems happened with stock power on a significantly opened up exhaust.  I think the factory was betting on max power being used for passing, rather than 10 minutes of foot to the floor.  Engine temp was reasonable 90C-ish until it suddenly jumped.  I presume when the bolt(s) let go.
This post was last modified: 04-06-2020, 01:44 PM by AlanMcR.
AlanMcR
baldur
Fast
506
04-06-2020, 06:06 PM #5
(04-06-2020, 01:42 PM)AlanMcR
Yes the web site is not great for that, but if you send them the measurements they will assist you in finding the right parts from their catalogue.
Baldur Gislason
baldur
Baldur Gislason
NZScott
HX30W 73/44mm
398
04-07-2020, 04:18 AM #6
(04-06-2020, 01:42 PM)AlanMcR Thanks, I'll look into that.  Their site doesn't seem very well oriented towards mixing and matching parts for vehicles that they don't make kits for.
Seems strange. This forum is full of people running 2-3 if not more bars of boost with fuel to match on stock bolts and HGs....
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
baldur
Fast
506
04-07-2020, 05:29 AM #7
You should also look at your pump timing. Injection timing is critical for cylinder pressures, and it has to be tuned on a dyno, the only correct advance is the least amount of advance that still produces maximum power. Overadvancing the pump not only hurts power but hurts the engine as well. Injecting too early produces much increased cylinder pressures.
This post was last modified: 04-07-2020, 05:31 AM by baldur.
Baldur Gislason
baldur
Baldur Gislason
AlanMcR
mind - blown
400
04-08-2020, 12:23 AM #8
I will check it, thanks. It is getting a new chain when I open it up.
AlanMcR
Tobulus
04-09-2020, 01:59 AM #9
Factory set the engine up for the german market, which means that people drive it for hours at maximum speed on the autobahn or pull 3.5ton trailers with a G with this engine.
Tobulus
AlanMcR
mind - blown
400
04-09-2020, 08:40 PM #10
That sure wasn't the case with the G350. Driven hard or hot they didn't last to 100Kkm.
AlanMcR
Tobulus
04-10-2020, 10:13 AM #11
(04-09-2020, 08:40 PM)AlanMcR That sure wasn't the case with the G350. Driven hard or hot they didn't last to 100Kkm.
Yes, the problem was even worse here in Germany. About 60% of the w140 S350 in the market got a new engine within the first four years.
Tobulus
starynovy
04-11-2020, 04:10 PM #12
Was chasing thing like this on bmv crapheap M51. Even developed my own 12.9 head studs. Turned out to be warped block and possibly weak threads in block. Had head off like 5 times and each time I torqued it felt like you are not torqueing at all. So kinda combination of both. Is your block flat? How does bolts feel when you tighten? There is no problem with factory bolts on this engine, save money on ARP studs. If you want you can buy genuine used 606 bolts from some breaker. Never seen used one from factory engine stretched by a bit, so perfectly fit for reuse.
starynovy
atypicalguy
04-12-2020, 11:14 PM #13
Yeah it sounds like either the head or the block needs decking while you change the gasket.
atypicalguy
