No fuel to injectors
I'm doing a build with an engine that i bought from someone elses unfinished project.
Supposedly a good engine, he had done work on it - water pump etc and fitted a Dieselmeken upgraded pump.
I've made all the connections and deleted the prefilter.
I have a manual priming pump and have got fuel into all lines, and all of the air out.
But on cracking the pump injector lines i never get any fuel out.
The shut of is in the correct position (clockwise, no vacuum).
I then fitted a electric lift pump to see if that helped and get some fuel coming back to the tank from the return.
However i have noticed that after a while stopped some of the lines do drain and have sir in them.
I have not checked the pump timing, but that would not stop any fuel appearing surely?
Is there anything else i need to do to prime it? Is there anything else that would stop in delivering?
I've rechecked the lines ad the all seem to be correct.
