No fuel to injectors
You can remove side cover to see that elements are connected to fuel rack( it happen to me once that rack was disengaged). Loosen the nuts on delivery valves and crank on with throttle on full - pedal to the metal. Once you get fuel coming out tighten up those on top of injection pump and loosen ferrule nuts on top of injectors and keep on cranking. Note: disconnect glow plugs at the glow plug controller so it is not powered. Glow plug drain battery fast and till you have fuel system bled of air are not needed. Be patient, it takes time to bleed entire fuel system of air.
