OM606.962 hard starting
Baldur can you provide a sketch of that? I'm a bit confused about teeing the regulator into the supply line AND return line. Did you mean the supply to the regulator and return to the filter? My OE lift pump is functioning fine so I didn't destroy it running unregulated constant on. Should I electronically regulate it so it will operate with a duty cycle less than 100%? i'm also afraid I may have destroyed the banjo check valve running this way. Anyone know the part number for it on the 606.962?
